Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 53
Thread: Guess Who Actually Did Some Woodworking...
    SE Minnesota
    2,550
    ...and has pictures to show for it.
    Actually I do manage to make small pieces out of large ones more often than it would seem. This time I have some proof.
    Last weekend I started on a new steering wheel for my sailboat. (Funny, that boat was "finished" four years ago but I'm still making stuff for it. ) I made the spoke blanks which I sent off to Ken Fitzgerald who kind ly volunteered to turn them for me. They are laminated up from cherry and hard maple.
    This weekend I made a trammel for my P-C trim router, milled the stock for the felloes, (the parts that form the rim of the wheel. They are called felloes on a wagon wheel, too.) and got the inner felloes cut to shape.
    I had enough stock cut to the size of the spoke blanks to stand in for the ones Ken will be making so I could at least get this far.
    The trammel was a bit of a challenge to work out. There aren't any extra screw holes on the bottom of the stock router base and there's not really that much vertical travel so the base couldn't be too thick. Since I have plenty of scraps I worked out what you can see in the pictures. I started by replacing the plastic base with one made from a scrap of 3/8" lauan ply I had left over from the boat. I used a piece of 12mm baltic birch ply for the trammel itself. I cut a channel in it for the new router base so it is a snug, slip fit. You can see some bits of pine on top that form the rails to hold the router down. Locking the router in place is a simple matter of drilling a hole and driving a screw through the rail, the base plate and the trammel. Not sophisticated but it works.
    The next step is to make the two outer felloes rings and then I need to get the real spokes in place so they can be milled to receive those out felloes.
    Thanks for looking.
    Steve Clardy Guest
    Hey!!
    Nice router sled/jig
    Charlotte, NC
    1,487
    Dave, that's a nice setup you put together! What wood are you using? That's not poplar you're using for the spokes, is it?
    Never mind...I didn't read "I made the spoke blanks which I sent off to Ken Fitzgerald who kind ly volunteered to turn them for me. They are laminated up from cherry and hard maple."
    SE Minnesota
    2,550
    Thanks Steve and Ed.
    The yellow poplar pieces in the picture were from some scrap that was close to the right size so I milled them to size when I was working on the spokes. The other three in the photo are scraps from the stuff I sent to Ken.
    Actually, much of my boat is yellow poplar including the keel and it has been just fine for a trailer sailor. The scrap I used to make the fake spokes was left over from the bow sprit.
    FWIW, here are a few shots of the boat from last summer
    The last one shows the yellow poplar bowsprit.
    Austin, Texas
    1,461
    Nice work , but in your case, doesn't the picture rule become "No Sketchup picture, it doesn't exist"?
    Charlie Plesums, Austin Texas
    Charlotte, NC
    1,487
    Looks like a fun little boat! What's with the iron jib hanging off the stern? Here's mine.
    I'm actually trying to sell it since I don't have the time to use it as much as I used to.
    SE Minnesota
    2,550
    Charlie, I suppose you are right.
    The boat. Not a completed SU model but it is drawn from the plans.
    The steering setup I designed. The wheel was pulled out of the air when I was drawing the setup. I should fix it.
    I do have a SketchUp model of the wheel I'm working on but it is at work.
    Ed, yours looks nice. Looks like it is a bit more go-fast than mine. The iron genny wasn't there for the first two years but most of the places I sail I need something because sailing into the dock is not a good choice. Too much chance of damaging sails, boat or people. On Lake Pepin the landing I use most is also used by fishing boats. You know, they back the boat in at highway speed, rooster tails as they leave the dock, rooster tails as they return. Drive the boat on the trailer at full throttle. I don't know why they even bother to back the trailer into the water. With all that power they ought to be able to drive the boat to the trailer no matter where it is parked.
    SE Minnesota
    2,550
    Latest Update on the Wheel
    Finally, I have some new pictures and a progress report on the steering wheel.
    First, a little boo boo. I neglected to consider the part of the outer felloes that would be cut away before I drilled the screw holes in the center of the blanks. Fortunately I had enough stock planed to thickness so I could make another six and also fortunately I didn't drill all twelve of the first batch.
    The pieces were glued together with super glue. the first piece was screwed down against a registration block which was removed before routing. Then each subsequent piece was glued and screwed down. To prevent gluing the pieces to the jig, I rubbed the surface with a bar of paraffin.
    Then I ran the router round the outside.
    After making the rings round inside and out, all the felloes pieces were rounded over on the router table. Then I shimmed up the stand in spokes to the height of the face of the hub. The inner felloes were then shimmed to put them midway up the spokes.
    And here is one of the rings laying in place on the spokes. I need to run the router round the spokes to create a recess for the outer felloes. Then it'll be time to sand all the parts and start gluing things together. Well, of course I'll need those spokes Ken turned for me.
    30,233
    Looking good, Dave. The latest pics helped to clarify how the circle cutting jig works. I like the way the jig adjusts.
    SE Minnesota
    2,550
    Thanks Vaughn. That little wedge of plywood in the picture showing the trammel in position was screwed in as a stop before I moved the router to cut the inner edge. That made it easy to reset the trammel when it came time to do the second ring. I made another little spacer that slips in between that stop and the base of the router to locate the inner position.
    When I get ready to cut the spokes, I'll have to move the router 1/4" away from the stops since the "keeper stock" will be on the opposite side of the bit so to speak.
  1. Guess what it is and what it is used for
    Last Post: 01-16-2014, 02:33 PM
  2. Guess what it is...
    Last Post: 09-12-2013, 01:43 PM
  3. Guess What?
    Last Post: 06-29-2009, 12:08 AM
  4. Guess what is this....
    By Toni Ciuraneta in forum Off Topic Discussion
    Last Post: 12-12-2008, 02:08 PM
  5. I guess!
    By Jim Suzda in forum Welcome and Introductions
    Last Post: 02-18-2008, 06:05 PM
