A little shopping, and a few problems with the purchased stuff.
Roger Tulk
So, Friday I had to drive my in-laws to Hamilton, which is right next to Burlington, which is where the Lee Valley store is. After I dropped off the in-laws, I went to Lee Valley with a shopping list. I got four Forstner bits, in the sizes needed to make a pepper mill, either the shafted or shaftless model. I bought a shaftless pepper mill mechanism, and a #2MT Jacobs chuck, as well as some candle holder rings.
So, I got home and opened the instructions for the shaftless pepper mill. First thing it tells me is that this requires a high degree of turning skill, which I don't have and forgot to buy at LV. I looked at the diagram, and figured I could make the cuts required, and even make a jam chuck to hold the body, etc. etc., but how do I cut the small rectangular groove in the inside of the body to snap in the 'legs of the mechanism? It looks like I would have to make my own scraper, as none of my tools, or the ones I see in the catalogue, will to the job. Maybe I should have bought the shafted mechanism.
So, today I turned a simple candlestick, 6" tall, on the lathe in cherry. Looks fine, but shows some evidence of a beginning woodturner. I parted off the top of the piece, and then put the Jacobs chuck in the tailpiece, and put a 7/8" forstner bit in the chuck. This I tightened into the top of the candlestick, and turned on the lathe. The drive spur turned, but the piece didn't. (I am stuck with using a Steb centre because of the type of HF lathe arrangement I have.) I stopped the lathe, and tighterned the tailstock. Now the lathe spun, turning the piece half-heartedly, and making some weak grooves in the top of the piece..I tightened the tailstock a little more. Now the darned thing wouldn't turn at all (on lowest speed.) With all this fiddling about, the steb centre made a neat, polished concentric circle at the bottom of the candlestick. I have decided to keep this as a feature.
I took the piece off the lathe, put the forstner bit in a hand drill and drilled the hole for the candle in the end of the piece. For some reason this took a long time. The 7/8" bit I was using was part of a set I bought in almost new condition for $20 last week. I don't think the quality on these bits is as high as I might like, but I did get a slightly off-centre hole drilled. I'll just tell my friends that my work is a little eccentric, like me.
Oh, the #2MT shaft was a pain to get out of the HF tailstock.
Now, is it most likely the lathe (not enough power) the spur centre (not enough grip) or the Forstner bit (not sharp enough?) Or some thing else. This whole experience is encouraging me to get another lathe. I have a #2MT four blade spur centre lying aroung that I would use in a lathe with a morse taper in the headstock.
Thanks for any advice!
In a contest between a Steb center and a 7/8" Forstner bit, the Forstner will win out just about every time.
I went back and saw some pics of your lathe, in the thread where you made a small baseball bat. Hmmmm ... I would be looking for another lathe, myself. Not sure if you have had a chance to do some turning on a more "modern" lathe, but yours seems to be missing several basic features that can make the experience much more comfortable and enjoyable.
First, the tool rest. It looks like you have to apply a wrench to loosen it, then reposition it, and then re-tighten with a wrench. Ouch!
I see what you mean about not having an available Morse taper in the headstock. (No way to knock it back out?) Another Ouch! I assume that your Steb center is gripped by the 4-jaw chuck that I think I saw? That's not a bad arrangement for spindle turning, except when you need to do a close-to-the-chuck cut on a small-diameter piece. (Watch your fingers!)
As for the tailstock ... it looks like there is no way to lock it in place and then advance a "quill" - which is the best way to drill a hole on the lathe.
So yes, I would be looking for a used midi-sized lathe at least. My 10-year-old Delta LA200 has all the features I described. It would be very hard for me to give them up.
Meanwhile, back to the Forstner dilemma. Can your chuck be used to grip the wood from the end? You know ... turn a small tenon, grip the piece in the chuck, and then try again with the Forstner? Oh, and if there is truly an issue with sufficient torque/power from the lathe, you could try drilling a smaller-diameter hole first, and then progressively wider ones. But again, you might not be able to reliably center each successive drilling with your tailstock arrangement.
Let us know if any of this is unclear, or if any other questions come up.
Kerry's right...a steb center won't bite the wood nearly as aggressively as a Forstner bit, so the center will spin out before much of a hole gets drilled by the bit. You really need to be holding the wood more securely at the headstock in order to drill it with a bit on the tailstock. I'm not sure there's a safe way to do it other than using the 4-jaw chuck to hold the workpiece.
On the subject of the "safe way" I hope you were not holding the candlestick with one hand while drilling it with the other. It's very easy for the Forstner bit to catch, and then things can get real ugly real quickly. I know this for fact, and have the scars to prove it. ;)
I also went back and looked at the pics of your lathe, and I've gotta agree with Kerry. The non-Morse spindle, the hard to adjust tool rest, and the very limited quill on the tailstock would have me watching Craigslist for something better. Having a more standard lathe would make the whole process of turning much easier and more enjoyable for you. ;)
Thanks very much for the replies, Kerry and Vaughn. I am going to try another candlestick this afternoon, and I will try cutting a tenon on the end and securing it in the chuck. I've never done that before, so it will be a new experience. I didn't hold the piece while I was drilling it, but I did hold onto it when I parted off the top. Almost caught my finger, but not quite. I won't do that again. The tailstock can be locked in place and the quill advanced. I have to use a wrench as the handwheel is missing. I bought the lathe with very little knowledge about lathes. :rolleyes: The guy who sold me the lathe had never figured it out, and never used it, so he sold it to me in the same condition that he bought it, except that someone had sold him a #2MT spur centre, figuring that was what he needed to get started. You are right about moving the toolrest. Also, it is so long that it gets in the way when turning small pieces.
There's a guy on Kijiji who has a Rockwell/Beaver lathe for sale. I will have to talk to the Memsahib about it. Maybe if I got some bloody knuckles off this one and said that I need a new lathe so that this won't happen again....
Thanks again!
Was it this lathe?
http://toronto.kijiji.ca/c-buy-and-...d-Wood-Working-Power-Tools-W0QQAdIdZ472415985
It's already sold, but I'd stay away that lathe for several reasons. These are listed in order of importance, at least as I see things:
First, it has tubes for the bed (similar your current HF lathe, except these are yound and your HF tubes are square.). Stay away from tube bed lathes, as they are flexible, and flex is a bad thing when it comes to lathes. (OK, there is one brand of very heavy duty European or Australian lathes that uses a tube bed - the name escapes me - but they are the exception, and would be way out of your budget range anyway.) Look for a lathe with a cast iron bed. (Just looking at Kijiji in Ontario, it looks like everybody and their brother is selling tube bed lathes.)
Second, the tailstock has a thumbwheel, and the quill has limited travel. Look for a lathe with a handwheel for the tailstock, and at least a couple or three inches of quill travel.
Third, that tool rest also needs a wrench to adjust. As you already know, that's a major pain.
Roger,
Kerry and Vaughn have already given good advice on getting a more modern lathe, so I won't add to that. The question you asked about " how do I cut the small rectangular groove in the inside of the body to snap in the 'legs of the mechanism?" is the one I wanted to address. I've never made a shaftless peppermill, but I have seen drawings showing the recess you refer to. I would do one of two things for that. I have a recess tool for use when chasing threads that would probably work for this. The other choice would be to make a tool from an allen wrench. Sharpen the short end with a flat on top and round the end. Make a handle, drill a hole and drive the long end in. I've made a few of these for hollowing ornaments and they work just fine. Like I said though, I've never made a shaftless peppermill, so take this for what it's worth.(not much) Part of the enjoyment I get out of turning is when I can make a tool to do a job and have it work!!
I have also read that some people cut those tabs off and epoxy the mechanism in place.
Was it this lathe?
No it is this one. I have a little trouble believing the one you showed me is a Beaver lathe, as I have never seen a Beaver like that one, and it doesn't appear to have the Beaver nameplate. Beaver became (or was taken over by) Delta, and some of their models are still manufactured. If I go to see this lathe, I will inspect closely the relevant parts.
Roger,
Thanks for this, Richard. I may try that a little later on, as I get better at this. In the meantime I have tsome lathe issues to solve, but I like your last suggestion. :thumb:
Roger, the one you're looking at is much better than the one I pointed to. :thumb: It does still require a wrench to adjust the tool rest or the tailstock, but those would not necessarily be dealbreakers, just an inconvenience. The core lathe (the bed, headstock and tailstock) are cast iron, and probably plenty substantial for what you'd be looking to do on it.
A few things to look for:
A #2 Morse taper on both the headstock and tailstock. Some of the older lathes used a #1 Morse taper, which is still workable, but you'll find the accessories for a #1 taper are much harder to find than a #2. (I have a mini lathe with a #1 taper, and it was not easy finding some of the things I wanted. Ultimately, though, I did.) Regardless of the size, having a taper on both ends of the lathe is critical, in my opinion.
Check that there's no play in the headstock bearings. In and out, up and down, or side to side. It should have no play at all.
I see the lathe you're looking at has a good chuck, but it does look like it would need a live center for the tailstock. Plan to spend somewhere around $30 on up for a live center.
I'm sure some of the other guys can add a few more tips to this list. ;)
Roger in my mind the bulk of the sale of this lathe is the chuck. That's the attractive part and the lathe is an add on.
Some time ago I think it was Al started out on our forum wanting to buy a bandsaw. You may or may not remember the posts. He was interested in the Porter Cable at the time if I recall correctly. Anyway at the time for him too budget was a serious consideration and it was to be pretty much his only tool. That is until the bug hit him. Sorry Al just want to have Roger review your experience. Well after all the advice Al bought I think a Grizzly and was very happy with it.
So with this as a preface, I would suggest that you consider saving up some coin and looking higher up the chain for a better lathe. I would even go so far as to suggest taking a trip across the border to Grizzly to stretch your dollars.
Vaughn has pointed out the rest needing to be managed with a wrench. I want to take this point way further.
Adjusting the position of your tool rest both in terms of height and in terms of placement is something that you do and in my view should be doing frequently as you work on a turning. If you buy a lathe like this you will find that the hassle factor in dealing with this kind of setup will get to you and you will definitely be upgrading sooner than you think if you plan to keep on turning.
There are several of the mini lathes that would do for the purposes of turning small items like pepper mills and even bottle stoppers or pens. There are many more small projects like this that are able to be made on a spindle mainly type of lathe. But they cease to be a pleasure when one is battling the machine all the time.
This also applies to speed changes. Its great and nostalgic to have an old iron machine but that's like me holding on to a public telephone when cell phones are now available.
I have visited Mack Cameron and seen his nice One Way lathe and were I an avid turner I sure would be saving to get one. But its only when you get to experience what a real machine should be like that you realise just how much it factors in to making the experience of using it enjoyable.
I purchased a cast iron busy bee lathe several years ago and it cost $315 at the time. I will admit to being cheap and totally uninformed at the time and I regret every day that I purchased the piece of junk. I had not joined the forum at the time and had no one to defer to for advice on the purchase. Its not a bad machine but having stopped at Grizzly and messed about with their version of the same category machine, the quality of finish as in machining that they accept versus busy bee is day and night in my opinion.
Other than Busy Bee the suppliers of machines in Canada are ripping us off so they don't and wont get my business anymore. For that reason I suggest take a trip or shop online and look to considering buying a new one and buying something that has a nice well machined bed and good easily adjustable rest with handle that locks and unlocks easily with all the features that Vaughn mentioned regarding tailstock and taper. There are cheaper Chucks other than one way available but I think One way stuff is well worth the money and its Canadian manufactured. :).
Rikon is one of the small lathes that has been mentioned here before as one option and when you look at the $$ I realise that you don't get a chuck with it but you have seen how people say the Spinny stuff is a vortex and there are good reasons for it.
Jet is another
General is another
Then look at what you can get at Grizzly and they ship to Canada now by the way. This unit has variable speed by the way in three ranges.
Now I realise that all the above are way beyond your ads price if that's your budget. But if you can find any of these kinds of lathes second hand at reasonable price they gonna be way more worth owning and you will get much better enjoyment.
I would like to make a further point specific to you. Recently you mentioned the effect of your illness on your feet. None of us are getting younger.
A smaller lathe like the minis can be mounted nicely on a mobile base and as I know Allen has done you could even take it indoors in winter and still have some fun turning and in my view maybe even sit down while doing it.
Think not just in terms of today but look further out this is not a purchase that you want to be having to put up with or upgrade again surely.
Well that's my 5 cents worth. BTW if you go south for more than 48 hours (ie visit some friend or the likes) and come home, you got a duty free allowance that would even save you the HST on the purchase of an item like this. Just saying not that I am against paying taxes but hey corporations get away with much worse tax avoidance.
Best of luck with your decision and purchase when you get to pulling the trigger.
