Results 1 to 7 of 7
Thread: Framing and wall covering for a Steam Shower?
    Central CA
    797
    The Realtor that I work for decided that he and his wife need a Steam Shower. I will start doing the tear out of their old shower this week.
    I seem to remember, from about 30 years ago, that there is some special needs regarding the framing and the wall covering, behind the tile.
    Has anyone had any experience in the building of a Steam Shower?
    Is there any special framing requirements as far as materials? I don't believe that regular greenboard drywall is allowable behind the tile in a steam shower. Again, any info?
    Thanks very much for any information and advice.
    Thanks, Mark.
    Custom Bonehead.
    My diet is working good. I'm down to needing just one chair now.
    "Just think how stupid the average person is, and then realize that half of them are even stupider!" --George Carlin
    Tokiwadai, Japan
    2,882
    Mark,
    Here's a link to a pdf on the subject. Hope it has something you can use.
    www.stewart.cs.sdsu.edu/0mystuff/gstewart/210143086_GS_Steamshower.pdf
    There are 4 pages to select, pics and text.
    Here's another: http://www.johnbridge.com/vbulletin/...php/t-108.html
    15,811
    Would that RockBoard or what ever it is called.......... Cement board..... not do the job? I'd imagine you would have to pay special attention to the chalking and maybe even a thick poly vapor barrier behind the cement board...?
    Take pics and document it, as we call all learn from it!
    535
    Never built one, but I've gotten lots of info from the John Bridge forum, that place is great! I think the blue drywall is more moisture resistant than green. I think concrete board is less water resistant than any gyp board, but much more ridgid - so better for tiling.
    Gotta run to Albuqwerky today, for the last of the drywall!
    Steve Clardy Guest
    All I've seen around here, is the tile guys using cement under layment.
    I have no experience doing it
    Toronto, Ontario, CANADA
    2,332
    I have never built a steam shower but I assume that the requirements would be much like those for a sauna which includes a shower and I have built three different saunas (one of them replacing a bathroom in a house) all with showers. In each case, I used knot free cedar for the surface
    -tongue and grove 5/8 inch or 3/4 inch thick .
    Cheers, Frank
    Elgin, IL
    442
    Quote Originally Posted by John Downey View Post
    I agree with John, the John Bridge forum is a great place, I did a quick search over there and there are quite a few in steam showers in progress now.
    I would recommend using Kerdi, you can just thinset it right over plain drywall. No need for cement board or green sheetrock. I used it on our masterbath shower and it worked great. Fairly easy to use also.
    Regards,
    Randy
  1. Steam bending for boat building with a clever non steam box idea
    Last Post: 04-27-2015, 04:50 PM
  2. uv resistant exotic wood covering
    By bob yetman in forum Finishing School
    Last Post: 08-16-2013, 08:19 PM
  3. A few projects to catch up on................#4 the steam shower
    By Mark Rios in forum Carpentry and Construction
    Last Post: 06-06-2007, 07:50 AM
  4. An interesting new project/job..........Steam shower.........
    Last Post: 04-15-2007, 04:02 PM
