Results 1 to 10 of 19
Thread: First laser kit
    Aug 2008
    Reno, Nv
    3,632
    First laser kit
    Star's and Stripes on an Ultra cigar. This is the first I've tried and it wasn't bad. If anyone notices a "design opportunity"....thank you and we'll discuss that later. 4 coats of CA with a gentle rub with 0000 steelwool. Thanks for looking!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    13,360
    How was it turning? My fear is getting a 'catch' after getting it all glued up.
    And you put the pieces in first, then wick in thin CA to glue the parts down, right?
    (I won't mention the design opp)
    Aug 2008
    Reno, Nv
    3,632
    Stinker!!
    So I worked off the instructions from Constants website...set pieces, tape in place, set tube and turn. With the stars...that worked well; had one that looked like a blow out and put the clip over that. The stripes worried me since the instructions don't call for glue! Once the stripes were place, cut and tube glued, I shot some CA on the surface...wadda I know! Used the carbide cutter with VERY thin cuts...you can hear it if it heads south so back off. 1/64" seemed to be the usual cut. I can't do a good sweep curve with my carbide yet, so worked the shear cut with my 3/8" V Thompson resulting in a "Happy" curve. Since the wood is stabilized, 3 coats of CA...knock it down with VERY light 0000 steel wool and one more coat. Finishes like butter!!! I was looking soft a soft..."worn flag" look...think I got it. This must be my longest post ever!
    13,360
    Nice job not getting any color bleed. That's my other fear with this kit.
    Aug 2008
    Reno, Nv
    3,632
    Ahhh...since it's stabilized, there is no bleed. Grain is filled so the chance for dust to fall in is nil. I thought the same thing, but after 240 and 400...clear as a bell. Constant does a great job...beginning to end.
    30,014
    First laser kit
    That came out looking sweet, JB.
    13,442
    I like that one, very cool!
    10,604
    Looks great Jim. I've been wanting to make one of those too.
    The center band looks unusual. Not bad, just different than I would expect. Was it installed it upside down ??
    Dec 2012
    Bedford, NH
    1,683
    Paul, it appears you have a good eye for detail. The aft end dia. does look larger the the fwd end, yet the semi-circular groove is oriented the same as the fwd spacer, plus it looks like it's aligned with a groove(?) on the gold band above???
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    Aug 2008
    Reno, Nv
    3,632
    Quote Originally Posted by Al Launier View Post
    I does look like that in the picture Al, but it all lines up very well. The gold blends into the black background at the edges. I had John Goodin make BTC bushings for the Cigar so it's nice and round.
  1. Laser Etching
    Last Post: 06-15-2015, 10:41 AM
  2. Laser Head Kit
    By Darren Wright in forum Programming, Troubleshooting, and Q&A
    Last Post: 03-20-2015, 10:56 PM
  3. Anyone do laser engraving?
    By Steve Ash in forum General Woodworking Q&A
    Last Post: 04-26-2014, 11:02 AM
  4. Laser cutting?
    By Joseph Shaul in forum General Woodworking Q&A
    Last Post: 10-09-2010, 11:05 PM
  5. Good Laser
    By Bill McQueen in forum General Woodworking Q&A
    Last Post: 02-12-2010, 02:47 AM
