Results 1 to 5 of 5
Thread: finish for cabinet in the bathroom
    Dec 2008
    falcon heights, minnesota
    5,610
    with all the moisture from showers, and my wife's mopping of the floor, what would be a good, long lasting finish? i was thinking along the lines of poly spar varnish.
    benedictione omnes bene
    www.burroviejowoodworking.com
    May 2011
    Cape Cod, Ma.
    1,553
    epoxy possibly?
    Austin, Texas
    1,448
    Quote Originally Posted by Dan Noren View Post
    ... i was thinking along the lines of poly spar varnish.
    I know the borg sells stuff called poly spar for use on entry doors and other exterior purposes. I have never understood where they got the name since poly is hard, scratch resistant (brittle), and intolerant of UV, while Spar varnishes are soft, flexible, and more tolerant of UV rays. If you want an oil based brush finish, this is probably a good choice, but it is likely to have an amber tint.
    As everyone knows, I am a bigot of Target Coatings waterbase finishes. I would personally use their EM8000cv which is a conversion varnish, very clear, very water and chemical resistant, durable to wear, sprays great with less than 30 minutes between coats.
    Charlie Plesums, Austin Texas
    May 2011
    Cape Cod, Ma.
    1,553
    I agree with Charlie!
    Charlie do you use the crosslinker with the cv?
    Nov 2012
    Wapakoneta, OH
    611
    Spar varnish is called a "long oil" varnish. Varnish is a resin cooked with a drying oil. Typically the resins are urethane (or polyurethane), alkyd, or phenolic (and some others). The drying oil is typically linseed oil, tung oil, soya oil, and a handful of other. What makes a "long oil" varnish is a higher level of oil to the resins, this makes the finish more flexible for wood movement. That said, I still wouldn't use a spar varnish in the bath. A good quality alkyd or phenolic would hold up very well. Waterlox Original is a phenolic/tung oil, and would really serve you well. A couple of others would be Sherwin Williams Fast Dry Oil Varnish (alkyd/linseed oil) or even Pratt and Lambert 38 (alkyd/soya oil). Waterlox is likely the most durable for your use.
  1. bathroom towel cabinet
    Last Post: 10-25-2015, 03:31 PM
  2. Bathroom Cabinet - Medicine Chest Replacement
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 06-30-2012, 05:36 PM
  3. Beveled mirror for Bathroom cabinet
    By Dan Thibert in forum General Woodworking Q&A
    Last Post: 04-30-2009, 06:33 AM
  4. Bathroom vanity and linen cabinet
    By Steve Ash in forum Flatwork Project Showcase
    Last Post: 06-15-2007, 01:22 AM
  5. bathroom cabinet
    By Dirk Boehmer in forum Flatwork Project Showcase
    Last Post: 03-30-2007, 06:43 PM
