Results 1 to 6 of 6
Thread: Secret bookshelf door
    Sep 2010
    Woking, Great Britain
    22
    I haven't posted a lot lately, but that is because I have been rather busy, i just thought i would share one of my latest projects with you, which is the build of a secret bookshelf door
    My wife bought about 2 years ago these double secret bookshelf doors. They were originally to be fitted as access doors to our library. We later decided against this, due to the fact we wanted more light into our hallway and changed the design that all the doors leading off the hall ways are to be double doors with glass panels, which meant we weren’t going to use these doors in their intended place
    The doors in question
    Doors1 by mcluma, on Flickr
    Doors3 by mcluma, on Flickr
    Doors4 by mcluma, on Flickr
    And the other side of the doors
    Doors2 by mcluma, on Flickr
    As we got underway with the refurbishment of our house we midway changed the ground floor layout. Originally we planned a double internal garage with at the back of the garage the plant room and Gym. Walls and doorways got build, and as these are structural walls they couldn’t be moved without a cost aspect. In the new lay-out the garage is to become our new lounge.
    So a solution had to be found for this doorway into the Gym
    Untitled by mcluma, on Flickr
    Which we had and that are the secret bookshelf doors!
    So after the floor was screeded the walls plaster boarded and plastered I set about to fit these doors.
    Originally they were fitted with 3 hinges each. Now there was no way I was going to use these hinges.
    1) The door weighs a hefty 100kg (or so I think, as it was more then I could lift) so this was not going to work with just 3 hinges (no ball bearings)
    2) The door is to open outward, so the hinges had to be changed and would then be seen from the inside
    I found the solution in using these Hafele floor hinges
    http://www.hafele.co.uk/Hafele35a1/I....10.760P1.JPEG
    These are rated up to 150Kg
    Here the doors in position to show what it’s going to look like
    The doors are bigger than the current opening, and to give it that “bookshelf “ feeling I had to build a frame to hold the doors
    Here the floor pivot hinge fitted on a 30mm threshold, This will enable later on the carpet to be fitted and still being able to open the door. I should have done the threshold in oak, but I didn’t
    And the top pivot hinge fitted
    With the doorframe done its fitting the other bits to the door. Had the help of my son to move the door about
    Here the bottom floor hinge receiver fitted (flush with the bottom rail)
    And the top hinge
    On this photo you can see the little hole in the style, this gives access to the screw to adjust the hinge in and out
    Door is fitted and adjusted
    The action is SOOOOOOOOOO smooth, and the whole door, despite its weight can be moved with just one finger – I really like these floor hinges
    Time to make it look more like a bookshelf, the sides are build out of oak, which will be stained darker later on, this will then match the rest of the furniture of the room
    We have two of these doors, and we like symmetry, I fitted the other door at the other side of the room.
    As I was working to a tight schedule with the carpets being fitted, my wife already started with staining the unit dark oak
    First coat of staining done
    Inside of door to white
    Sep 2010
    22
    Prep work for fitting the crown moulding
    Here the crown fitted
    First coat on the crown and second on the sides of the unit and prep work underway for fitting the rads
    Yesterday the carpets got fitted, so here is the final product .
    Over the weekend I will be fitting the electric door opener with a concealed button (pictures and video to follow
    Thanks for looking
    Independence, Kentucky
    1,354
    Very nice installation Chris and I like the way you documented the install. A very clean look and I love the secret door aspect. Very well done.
    4,698
    Nicely done.
    I have a friend who has a "secret" room that was looking to install a bookshelf door.. we started doing the math on the weight of actual books and the hinge required was .. impressive (not to mention the surrounding re-enforcements). For some reason neither of us thought of having faux books like you did here - seems obvious in retrospect..
    Wonderful solution and good use of the doors. Very cool feature, useful and sure to be a conversation piece.
    30,002
    I like that a lot. Thanks for posting the photos.
  1. Low Bookshelf Bench
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 09-01-2013, 04:31 PM
  2. Simple bookshelf
    By Steve Southwood in forum Flatwork Project Showcase
    Last Post: 03-08-2011, 02:03 PM
  3. need y'all to keep a secret
    By Frank Fusco in forum Lathe Project Showcase
    Last Post: 06-10-2009, 11:36 AM
  4. First bookshelf
    By Al killian in forum Flatwork Project Showcase
    Last Post: 01-01-2007, 10:00 PM
  5. Bookshelf and new Camera ( Yea ! )
    By Bartee Lamar in forum Flatwork Project Showcase
    Last Post: 12-31-2006, 04:07 AM
