Results 1 to 10 of 14
Thread: Problems using a drill chuck...
    Aug 2011
    Hitchins, Kentucky (Northeastern part of the state.)
    80
    I finally picked up a 1/2" drill chuck to use in the tailstock of my Delta 46-460. My first couple attempts with it have not gone according to plans. The first thing I tried to drill was a pen blank with a 7mm bit. When I advanced the bit enough for it to start biting, it proceeded to bind, causing the quill to start advancing on its own, pushing the tailstock back. I tried adjusting the blank in the pin jaws of my chuck but it did not help, I could not stop it from binding and advancing the quill and pushing the tailstock back. (I don't have a drill press.) Later, I tried using a forstner bit in the drill chuck, but every time I would start to get a bite in the wood, it did the same thing. Has anyone had this issue before? I am pretty new at this, so I'm leaning towards operator error. Any pointers?
    Aug 2008
    Reno, Nv
    3,632
    Ray, check your bed for alignment. Put your live center in the tail stock and a dead center or whatever center you have in the head stock. crank the tail stock until the points on each are just a millimeter apart...are they aligned? Start with this and we can go from there...post a pick of the set up if you can.
    Central PA
    638
    sounds like the alignment pin/ quill lock is to far out letting the quill to spin and therefore advance. Does the chuck spin? It shouldn't.
    Aug 2011
    80
    Here is a picture of the alignment.
Name:	resized alignment.jpg
    The chuck started spinning when the drill bit was biting into the wood. I did check and the quill lock was not in the groove of the shaft. I'm not sure if it was like that before the issue or not, because it did come out at one point. I will have to try it again, tomorrow.
    13,353
    That's weird. I actually used my little jet midi lathe to do a little metal working this week. It required having a drill chuck in both ends of the lathe, and it worked fine.
    Central PA
    638
    Quote Originally Posted by Raymond Scott View Post
    I just checked my jet 12-36 and if I disengage the quill lock far enough that the lock shaft comes out of the groove and turn the quill the quill will advance. So I think you need to have the quill lock in far enough to engage the groove then you shouldn't have a problem.
    Feb 2013
    Clyce, Texas
    185
    One other thing to check is your speed. When you're drilling, slow down to 200-400 rpm. That will help keep the bit from biting and pulling the tailstock. When I drill, I hold the drill chuck lightly to help prevent it from catching and pulling the chuck out of the tailstock. Every 10-15 turns of the tailstock, you'll need to back out and clean out the drill bit. Slow speed and cleaning the bit will also help it run cooler.
    Aug 2011
    80
    Quote Originally Posted by Dave Black View Post
    This makes sense. This was my first time turning without the quill lock tightened down, so I probably had it too loose.
    Quote Originally Posted by Steve Kniffen View Post
    This is very helpful. I need to make a chart for which speeds to use for different applications.
    One other thing, the back cover for my PSI live center keeps coming unscrewed while turning. Do I have to worry about it?
    868
    [QUOTE=Raymond Scott;375298]This makes sense. This was my first time turning without the quill lock tightened down, so I probably had it too loose.
    Blue thread lock on the threads the next time it comes loose!
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    11,825
    I'm having a problem with this question. When you advance your hand should be on the wheel of the tailstock. At the first hint of a problem you should have stopped advancing and backed off the bit. Then what you describe would not have happened. And, the tailstock moving back is near impossible it is locked properly. Several other factors could be at play. I'm thinking 'very soft wood' and/or dull drill bits.
  1. GMC-3 mini chuck problems
    Last Post: 05-03-2014, 11:23 AM
  2. Replies: 10
    Last Post: 12-04-2011, 10:51 PM
  3. makita 10.8 drill driver / impact problems ?
    By patrick anderson in forum New Tools
    Last Post: 06-14-2010, 02:07 AM
  4. Replies: 0
    Last Post: 11-07-2008, 01:29 AM
  5. That Drill Chuck is on Tight!
    Last Post: 06-24-2008, 05:37 PM
