Results 1 to 10 of 13
Thread: Drill bits for pen blanks
    Aug 2011
    Hitchins, Kentucky (Northeastern part of the state.)
    80
    Question Drill bits for pen blanks
    After finally getting a drill chuck for the lathe (and getting it to work properly!) I decided to try drilling some pen blanks. I got a 7mm bit from PSI and find it to make the holes somewhat over sized. The CA glue I had been using just can't hold the tubes in the blanks I drilled. Is this a common issue?
    S E Washington State
    3,777
    Check the bit with a mic and see if it is undersized. That can happen. Not real common. Get some 5 or 15 minute epoxy and use that instead of CA to glue the tube. I have never had a tube fail since I started using epoxy several years ago. Make sure you sand (rough up) the tube before glueing it in.
    Lots of videos on youtube: https://www.youtube.com/results?sear...in+a+pen+blank.
    "We the People ......"
    I've had several drill bits from Penn State that ended up drilling holes that were too big for the tube. (Had it happen once with a bit from Arizona Silhouette, too.) In one case, the holes were ridiculously oversized, and of course it was for one of Penn State's most expensive kits. It was at that point I vowed to not buy any more of their products. Paul's suggestion for epoxy is a good one, but I'd also find a better source for a new 7mm drill bit (some of the real pen turners here will have suggestions) and toss the one from Penn State.
    Apr 2010
    Bouvard, Western Australia
    14
    That's why I always drill a trial hole in a piece of scrap wood & try the brass tube for fit.
    HTH
    Col
    A tidy workshop is the sign of a sick mind.
    www.bouvardbush.com
    13,363
    +1 on epoxy for gluing in the tubes...
    Aug 2008
    Reno, Nv
    3,632
    You're having some wobbling from not centering your starter hole. If you are using a jobber bit, it will happen every time. The longer the hole...and Slims have a long tube, the more deviation you'll find. If you get way into pens, get a hole starter bit...Little Machine shop and other places have sets for cheap! Only way to get a straight shot every time. After that, a brad point bit is your friend. With an even bore, no need for epoxy, thick CA is made for just that purpose.
    Hi,
    The most reliable drills for my penmaking since the 80,s has been the DeWALT EXTREME 2 the 7mm version is HSS-G 7mm DIN 338 DT5050 originally developed for drilling Stainless Steel made in the good old USA. It was discontinued for a while for Slimlines I have drilled up to 800 blanks per drill, because they have a true mini drill point cant sharpen them, do the maths just how cheap can you get, the dont track for me no breakouts I never change my drill press speed fairly fast and be careful the drill is sharp on the flutes and deserves respect, available in many sizes.
    In respect to even the most expensive drills I have ever used I take in Calipers or a Micrometer and measure all drills for critical use place them in baggies marked with the rael size usually drill a fraction under and use my real old Hercus Metal Lathe and various cutters to finish sizes. Works for me.
    Have success Peter.
    Tellico Plains, Tennessee
    4,353
    Quote Originally Posted by Col Smith View Post
    HTH
    Col
    Me too... I want a nice snug fit when I insert the tube...
    Chuck
    Tellico Plains, TN
    Aug 2011
    80
    Picked up some epoxy today and ordered a starter set from Little Machine Shop. Next, I'll be looking at drill bits. I'm off tomorrow so I hope to be able to get some time in the shop. Thank you for the responses!
    Goodland, Kansas
    4,834
    Like Jim mentioned brad point bits are your friend. Since I have changed all my pen bits to brad point I haven't had a problem. Above all crank your bit in slow. I use 5 minute epoxy on all my pen kits, toothpick and pill holder kits. I also use dental sheet wax to plug the ends to keep the glue out of the tubes.
    Bernie W.
  1. Drill Bits
    Last Post: 10-17-2010, 05:02 PM
  2. Delta/Milwaukee brad point drill bits NOS
    By ken werner in forum Old Ads
    Last Post: 09-05-2009, 08:36 PM
  3. Drilling pen blanks with bench top drill press.
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 05-25-2009, 11:57 PM
  4. Using router bits in a drill press
    Last Post: 01-08-2008, 01:26 AM
  5. Drill bits for a brace
    By Al killian in forum Neander Woodworking Q&A
    Last Post: 11-28-2007, 07:25 PM
