Results 1 to 10 of 12
Thread: gaining some space and need a plan
    Sep 2007
    Central (upstate) NY
    1,457
    This is my old shop space: http://familywoodworking.org/forums/...on-in-progress, it was a one car attached garage.
    I'm moving to a two car detached garage. A friend of mine with a truck unexpectedly dropped by today and we brought over my RAS, BS and jointer / DP (they share a mobile base to counter the wobbliness of each). The garage is about 20 feet square. It has two overhead doors which I define as the front and a mandoor (installed by me, including framing up some extra space above the door with glass blocks) on the right, right about halfway back. I promise to post pics when I work up the energy - we're still moving stuff. Mostly my stuff at this point - flat wood, bowl blanks, tools, a workbench / assembly table (I'll be able to move the lathe off of this table! ), a couple #6 and one each #8 and #62 handplanes; Olympic weight set; wargaming miniatures; sewing machine (a nice mechanical Pfaff that will, with minor protest, go through 3/8" leather); a professional chemistry and mathematics library that, sadly, is likely going to shrink due to mold following unexpected flooding while I was rehabbing the new house - thankfully we'd already packed and staged most of the gaming books); and, well, I think that about covers what is left to move, oh, wait, some carboys for homebrewing! Knew I was forgetting something.
    So, on the left side wall just inside the left overhead door I installed a couple stud pieces to use as clamp racks. In front of this is going to be the drill press and jointer (same mobile base to avoid wobbliness). Continuing along the wall is going to be the RAS and then assembly table / workbench. The thought (thanks to a coworker) is that I can open the overhead for long pieces when needed. I really need a pic for this. It has been awhile, is it ok that I'm using Flickr as a pic host instead of uploading here?
    13,450
    Sounds like a good plan. It's ok to use flickr.
    I know it's been a while since you've been here, but the new forum software will re-size your pics automatically when you upload them. I use the "Insert Image" icon on the toolbar (hover them to see the names), then choose from either computer or by URL. If you do it via a URL there is an option to have it copied to the forum, it's up to you if you leave that clicked or unclicked.
    Sep 2007
    1,457
    I took some pics, but I need to do some post on them first. They need some serious exposure adjustment and I want to stitch them into a ppanoramic. First I want to try to install house Ethernet and get ice cream.
    Sep 2007
    1,457
    Ok, did some post. These may well be the worst photos I have ever published. Is there a way for my photographer friend Ned to not see these? I'm capable of better and will add a better shot at a later date. I had wanted to make one long pano shot, but my starting photos were so bad the best I could get was two panos.
    So, where was I? Well, you can see the DP, jointer and RAS (still need to put on the table and reshim it - may well remake the table from scratch). Continuing to the right will be the assebmly table / workbench / router table, but without the lathe on it. The scroll saw and BOSS will be in the corner. The lathe will be under the left boarded up window space and then the bandsaw. To the right of the bandsaw will be some pegboard for storage and that far right corner is going to also house my Olympic weight equipment. I need the ceiling height of the garage for the clean and jerk. I think the shelves may go in the middle of the garage, delineating the two bays and the planer / grinder will be near the center monopost.
    Open to ideas.
    left_DSC4127_4129 by mek42, on Flickr
    right_DSC4130_4134 copy by mek42, on Flickr
    Sep 2007
    1,457
    Oh, check out that mandoor installation with those awesome dwarfy glass blocks!
    10,604
    Lot's of great space Mark. Looking forward to see hoe you set it up.
    What do you have out there for electric service ?
    Sep 2007
    1,457
    Knob and tube 120V, lol! After we sell the current house, replacing the other overhead door and upgrading the electricity get on the to do list.
    13,450
    Layout sounds like it would work fine. Will you be insulating and closing up any of the space to be able to use it during the winter?
    You got some crazy framing going on in that garage, looks like a few supports have been added over the years and patches done. Are there any supports going from that center beam up to the ridge or are there just the cross braces holding the sides in? I'm not knocking it, looks like a great space to have, just curious why there are all the supports down the middle and the angled ties on each side, they're all in places that seem to be a bit in the way, but may just be the perspective of the camera.
    Edit: NM...looks to be balloon framed, which explains some of it.
    Sep 2007
    1,457
    I installed the monopost and plan on taking out the wood post once I anchor it to the pad. I also plan to marry some 2 * 8 studs to the two by three, real two by three, on twenty four that is the structure. From these I plan to build a loft in the back half of the shop.
    Thee house was built in nineteen twenty. Sadly, there is not a single long span timber in the garage. Everything is some kind of crazy marriage of multiple studs. Ned can take full credit for my shop not collapsing, though. He contributed the maple scrap I used to shim above the monopost to provide support for both married timbers.
    Right now, we plan to use this house to reset ourselves financially. If we end up liking it here, we may do more to the structures.
    Jan 2011
    3,798
    Looks like a fine space though it's somewhat bittersweet...Uhggg, more work...but...Yehaw, it's shop work
  1. always think your plan through....
    Last Post: 11-01-2012, 03:08 AM
  2. just plan ol funny
    Last Post: 06-12-2012, 01:43 PM
  3. kitchen plan
    By Ned Bulken in forum Carpentry and Construction
    Last Post: 11-27-2010, 06:50 PM
  4. Plan help
    Last Post: 06-25-2010, 02:35 AM
  5. Keep Sake Box Plan
    By Ron D Jones in forum Designs, Plans and Sketches
    Last Post: 09-14-2007, 03:06 PM
