Results 1 to 10 of 16
Thread: allen had best not look at this board....
    Dec 2008
    falcon heights, minnesota
    5,609
    well, i put my foot in it this time! this is the oddest board i've made to date. it is maple, cherry, and walnut, and is designed to give allen a headache if he looks at it too long. details to follow as construction occurs, but for now, i have all of the lumber for this and another project, all of the parts cut, then planed to thickness (1/4"), and the first blank glued up, and then the rest glued up. can't wait to finish this one up.
    Attached Thumbnails Attached Thumbnails 001 boards for projects.jpg   002 maple parts cut.jpg   003 walnut parts cut.jpg   004 cherry parts cut.jpg   005 all parts planed to thickness.jpg
    benedictione omnes bene
    www.burroviejowoodworking.com
    Sep 2007
    Central (upstate) NY
    1,457
    Wait a minute, one of those boards said birch on it. Was that the special maple birch?
    Dec 2008
    5,609
    nope, that one and a couple of the walnut boards are for another project i didn't get to this weekend.
    Jan 2011
    3,798
    Son ofa birchen typo's
    Looking forward to seeing the final results!
    edit: shucks too slow I was!
    Dec 2008
    5,609
    well, made a bit more progress today. i found that i needed more of the maple blocks, and had a surplus of walnut blocks. while the new maple and cherry blank was setting up, i planed the bottoms of the other blanks, and started working on the second go round of the new wine bottle holder. once the new blank was set up, it got its bottom planed too. then it was over to the planer to bring them all down to the the same thickness, and cutting the squares. as can happen at times, i had a bit of a boo boo while cutting the squares. instead of waiting for the blade on the miter saw to stop, i let it up and >bing<, one or more of the teeth caught the blank and sent it into my finger tip, causing a small gouge, a bit of blood, and no small amount of surprise (like all good lessons, this one hurt a bit too). no worries, a bit of a bruise and a small cut. after that, the reset of the cuts went ok. on a side note, there are 48 walnut squares, and 35 cherry squares. while we were at the y, i set up the squares in the proper orientation, and thankfully everything was nice and square. now it is on to making a jig to make the necessary cuts to realign the direction of the strips. sorry about not too much detail with the squares, don't want to give allen any more headaches.....
    Attached Thumbnails Attached Thumbnails 008 last bit of cherry glued up.jpg   0009 bottoms planed flat.jpg   010 planed to thickness.jpg   011 cherry parts cut.jpg   012 walnut parts cut.jpg
    Dec 2008
    5,609
    now that the bookcase is out of the way, i can get back to this bit of torture. i have already designed a jig to cut the parts to the needed shape, and got a start in building it tonight. it was a little too late to do more than get this part of it done.
    Attached Thumbnails Attached Thumbnails 013 beginning of jig for recutting.jpg
    Dec 2008
    5,609
    ok, now on to the really scary part , recutting all of the squares. having the jig with the hold down will make it that much safer. i have decided to post a little teaser pic, of the blocks set up, and the board that is yet to be. more pics to follow after the cutting is done.
    Dec 2008
    5,609
    well, the really scary part is done, the new jig worked like a charm, and all of the parts (83 of them) came out nice and square. now the really fun part, gluing all of those parts together. can't wait to sand it, and hit it with the oil. this one is definitely going to next year's state fair. my wife has laid claim to this board, but not as a cutting board, it's too nice for cutting chicken on, it's a work of art. so she is going to laminate a photo on it, and hang it on the wall.
    Attached Thumbnails Attached Thumbnails 015 finished jig.jpg   016 first of 83.jpg   017 parts laid out after recutting.jpg
    30,014
    Very nice. I hope the glue-up isn't done yet, though. I noticed one of your pieces is upside down.
Name:	Dan Noren Board Annotated.jpg
    Dec 2008
    5,609
    thanks vaughn, i didn't notice that one. the glue up doesn't start until tomorrow. i just wanted to see how it looked with a quick setup.
  1. Vertical Chest Board and Chalk Board
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 02-25-2012, 10:56 PM
  2. Allen
    By Tony Bilello in forum General Woodworking Q&A
    Last Post: 06-20-2011, 11:18 PM
  3. Allen - This one has your name on it
    By Sharon Korn in forum Off Topic Discussion
    Last Post: 03-17-2011, 09:13 PM
  4. One for Allen or Ken
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 02-19-2011, 08:28 PM
  5. Hey Allen
    By Bob Gibson in forum Off Topic Discussion
    Last Post: 11-10-2009, 01:07 PM
