Results 1 to 7 of 7
Thread: uv resistant exotic wood covering
    As a retirement hobby, I build multilevel circular bird houses with veneer exotic woods such as bubinga, padauk, canary wood, king wood, mahogany, and many other types of exotic wood. I am looking for a high uv resistant clear covering that will protect those woods from fading when exposed to sunlight. Any suggestions?
    5,318
    First of all, welcome to FWW! Stick around; you'll like it here.
    As for the finish recommendation, a marine varnish will likely be your best bet.
    One of the absolute best ones is Epifane. It's a bit pricey, but is very durable.
    That said, any outdoor finish will require frequent (yearly?) touchups or recoating.
    Nov 2012
    Wapakoneta, OH
    610
    Epifanes would be the best. You could also try untinted exterior oil paint base. The ones for the darker colors (normally base #4), believe it or not, without tint it looks very much like a varnish when it dries, and has very good UV protection (more info here). One last note: be sure to avoid the box store "spar" varnishes...they are almost all made with urethane resins, that in itself makes it a poor outdoor finish. The marine store stuff (like Epifanes) is a much better product.
    Jun 2007
    4,944
    I have wondered about this. Even though I never did ask. So I found this to be an interesting thread.
    Thanks and Enjoy,
    JimB
    VOTING MEMBER
    new york city burbs
    10,184
    if you use mahogany, sikens, not sure which one these days, but I used it on a door entrance a few years ago, made of mahogany, hasn't faded one iota.
    Human Test Dummy
    11,825
    Bob, welcome to the forum.
    As others said, a marine varnish is best. But you are looking for something that doesn't exist, really. So "best" only means the process is slowed down a bit. I work quite a bit with Osage Orange and would just love to keep that bright orange/yellow color, but, alas, it is not possible. I have tried lots of things. All that will work to keep the color is to not expose your piece to light at all, keep in a dark vault.
    Apr 2009
    Outside the beltway
    5,250
    MLC has a 2 part epoxy that works well. I was doing an estimate at the Pentagon yesterday and thats what is being recommended. Finish looks great and very durable.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
  1. Premium Hawaiian and exotic wood skateboards
    By Tyler Bliss in forum Flatwork Project Showcase
    Last Post: 03-25-2012, 01:34 AM
  2. Exotic Wood Gloat
    Last Post: 02-06-2011, 01:14 AM
  3. interesting source of exotic wood
    Last Post: 12-07-2010, 01:26 AM
