Results 1 to 3 of 3
Thread: Finishes bad for blades...
    Baltimore, Mary land
    68
    Sometimes I receive wood that already has a finish on it. Like a recycled oak door that I demolished for the wood. So my question is, can wood having a finish on it already - be damaging to tools. Like if you plane a board that has glue build up on, it can sometimes chip your blades.
    Will it dull the saw blades or chisels?
    Should the wood be stripped first?
    The finishes so far have been Poly or spar varnish, not built up like pre-finished hard wood flooring.
    Just curious...
    The other day I was ripping a 2x4 on my table saw and the cut started to run off, then I saw smoke and now I have a wobble dato blade.. haha Oh, did I mention that the board had about an inch bow and crown in it... It would have been cheaper to just buy a new 2x4, instead of a 2x4 and a new 10" saw blade!
    George Blevins
    Astriapo@earthlink.net
    george, it ain`t the finish on old boards you need to worry about...it`s the metal that could be hiding under the finish.....(unless the finish is lead based paint)
    688
    What Tod said, and it will probably get your blades dirty quicker than regular wood, may have to clean them often.
  1. Tried and True Finishes
    Last Post: 08-16-2011, 04:22 AM
  2. Finishes that are different
    Last Post: 05-11-2010, 03:16 PM
  3. Please help me decide what finishes to use
    By Joe Provencher in forum General Woodworking Q&A
    Last Post: 12-18-2009, 12:11 PM
  4. Finishes for turning
    By Drew Watson in forum General Woodturning Q&A
    Last Post: 11-24-2009, 06:20 PM
  5. Rolling pin finishes
    By Jonathan Shively in forum General Woodturning Q&A
    Last Post: 05-03-2008, 03:09 AM
