Results 1 to 9 of 9
Thread: Cleaning a drum sander
    Constantine, MI
    7,892
    Other than replacing the paper, does anyone know of a good way to clean off a drum sander belt so it does not burn the object being sanded?
    www.wrworkshop.com
    13,366
    I use one of those big crepe rubber erasers.
    Seems to work good on most things except when cherry gets burnt on it real good.
    May 2011
    Cape Cod, Ma.
    1,553
    I agree with Brent. also I always presand most if not all dried glue off the piece before sending it through minimizing build up
    Constantine, MI
    7,892
    Just about wore one of those out. Cleans the belt well except for the hard, glossy, crusty stuff.
    www.wrworkshop.com
    Oct 2007
    Schenectady, NY
    912
    I have soaked some of my strips in Simple Green overnight and then scrubbed them clean in the sink or plastic tub with a good stiff brush. Gets most of the burned on residue off. Rinse well and hang them to dry. Seems to work out OK.
    Don Orr
    Woodturners make the World go ROUND
    May 2011
    Cape Cod, Ma.
    1,553
    another note. if its not the glue and its burning the passes are too aggressive for the grit being used. If you need to take that much off go to the next or even 2 grits courser and take shallower passes I learned that the hard way with my woodmaster now I start at 80 and go from there. it actually takes less time than the way I originally used to do it and I get a long time out of each wrap. (pine and other resiny woods excepted they gum up just looking at them)
    Austin, Texas
    1,448
    When I had my performax sander, the best solution I found was to lay the strips out on the driveway and power wash. Simple green if a solvent was required, then rinse and dry in the sun.
    I gave up on the eraser game. It made the belts look pretty, taking off the light dust that didn't matter, but it didn't help the hard stuff that was causing the problem.
    Charlie Plesums, Austin Texas
    9,077
    Bingo. Pause in your sanding more often to clean and avoid the burned on stuff altogether. I know its tough to stop when you are really running through the steps but, its easier. I just lift the lid and lightly run the rubber over the surface end to end, close the lid and go back at it. The longer you run at a time, the hotter things get and the more often you should pause to clean. All that being of no help once you have what is shown in the pic; I pick at it with an awl and scrub with a fine wire brush. If it is stubborn, a soaking will often help. Prevention is easier but, we all let it get away from us now and again.
    Nov 2012
    Wapakoneta, OH
    611
    I've tried probably 4-5 methods of trying to recover just such a belt, and was never successful. the big crepe thing is good, and works if you use it often enough....but once it reaches the stage in your pic, it's pretty much there to stay. So other things i've tried is soaking them (once in Simple Green, aopther time in mineral spirits), that didn't work./ So I even tried to pick all the small pieces of glaze off with a dental pick, got it cleaned as good as I could, then it clogged right back up. I've given up on saving the belts...the best thing is prevention. For prevention, I've done the normal things: no more fine grits (150 is the finest I'll use, more often it's 120), no soft wood through the planer, very light cuts, and a slow feed rate. Still I manage to burn 'em every now and then.
  1. Drum Sander.....?
    Last Post: 10-23-2011, 03:40 PM
  2. Jet 10-20 Drum Sander
    By Steve Southwood in forum New Tools
    Last Post: 10-16-2009, 02:52 AM
  3. Drum sander
    By Ed Gerhard in forum New Tools
    Last Post: 09-21-2009, 06:17 PM
  4. Belt Sander vs a Drum (thickness) Sander
    By Ken Close in forum New Tools
    Last Post: 11-26-2007, 01:36 PM
  5. V Drum Sander kit...........??
    Last Post: 04-14-2007, 12:32 AM
