When you are ready to speak English to this city boy, please let me know. Beautiful pics!!! Enjoy, JimB
Jim, let me see if I can decipher this for you!
Yeah, rotary mowing does have some advantages at times. Will put up with those smaller engines. Next summer plan on playing with the exhaust and mufflers though and see how quiet I can get them.
A rotary mower is just like your push or riding mower, a horizontal blade that cuts and chops the grass. A regular horsedrawn mower is a sickle bar mower where knives slide back and forth in a reciprocating motion. This grass just lays back on the pasture and suffocates the grass underneath it. Great for hay making but not pasture maintenance.
They (the ponies) are movers for sure. And I would agree 100%, it is a lot easier holding them back a little than trying to keep one walking!
This is in reference to their stride or way of going. I liken it to when I was in elementary school walking downtown with my 6'3" Grandfather, his stride was definitely longer and ground covering than my little legs could imagine.
Cannot back that rig more than 5'. The back mower hooks to the front mower on the side, the front mower hooks offset to the forecart. Now when I get the two married together, yes this team will be able to back in and clean up the corners better.
The ponies/team is hooked to a two wheeled cart via a tongue. Behind that using a standard pin hitch the first mower is attached to the fore cart. Then I attached the second mower to the right rear corner of the first mower and offsetting the tongue so they mowed two separate swaths. Backing this conglomeration is near impossible due to the different hitch points and angles. What Peter was asking for a pasture with 90 degree corners, generally when mowing you make the corner as a curve, when you straighten out to continue down the field in order to mow the unmowed portion in the corner you back the mower into the corner over the unmown grass.
The pasture got over grazed during last year's drought.
No rain, no growth, I had to sacrifice one pasture and keep the cows on a field so they ate hay but any time a green blade of grass showed above the ground they ate it off. This allows the canopy to be open and weeds grow like wildfire. I don't use chemicals generally on my farm so I try to control weeds by mowing them before they can flower and reproduce. I had great control of my pasture weeds until last year and then this year I started mowing late so they got a headstart on me.
If time allows, thinking I am going to plow some of that pasture under and plant some open pollinated corn.
I will plow the pasture grass/weeds under and next spring plant corn that is not a hybrid. Meaning I can save ears of corn that are large and well filled as well as coming from stalks that are standing well. Seed from Open Pollinated corn raise corn like themselves. Hybrid corn is raised from many generations of crosses that end with a terminal cross that is the seed planted, the corn grown will not create a plant like it came from.
Have a two row, one horse corn cutter that I bought with my mule in mind for shocking corn next Sept..
Shocking corn is the early version of silage. I will cut the corn stalks off at ground level and then tie them in a bunch so they dry. My plan is to purchase an electric chipper/shredder and then bring a shock of corn into the barn and run the stalk and ear through the chipper/shredder making fresh feed/silage daily for my calves.
These girls need some more hours on them before cultivating corn, but haven't gotten much done in the way of hauling manure yet so that will put some time on the team.
Girl horses are called mares. Hours, they need time working. They were trained young on a wagon, so they don't know about walking specifically a straight line like down a row. Time in the field, especially plowing where one of the team has to walk in the furrow they will learn quickly to step into the furrow and walk in it. That is good training to teach them to follow a natural line like a row in a field. Next year at this time, my off mare (mare on the right when looking from behind) will know to walk in the mown grass beside the unmown grass which will place the offset mower correctly over what is to be cut.
Yeah they are nimble!! They got away from their previous owners a few times and got it in their heads to not work.
Ponies or horses, cattle even dogs, once they learn to get away with something, they will continue that habit for a long time. Since these learned to pull away from you when leading and then when harnessed not listen or respond to the correct commands, they were something of an accident waiting to happen. Nimble, they can turn on a dime and give you four cents change! They are quick.
They have a work ethic unlike any pony I have owned in some time. If they are true of the breed, I am impressed with Fjords.
Animals like people, some love to work others are jerks. These willingly work everyday all day. (with noon breaks and depending on weather other breaks)
They don't stand out in the open yet.
By this I mean I can't stop them in the field and get off of the forecart and get a drink or adjust their harness or work on the mowers as they won't stand still. If I am at the hitching rail, yes, they will stand. They just haven't worked hard enough to learn the benefits of rest when it is offered. A few teams ago, I had a team that I could drive up to a closed gate, get off the manure spreader, open the gate and tell them to get up and when they got through the gate tell them to whoa (stop). I then could close the gate and get back on and finish the job. This type of training just happens from continual work.
But a few days of plowing will really reinforce that lesson so not worried, they know whoa, just not stand.
Plowing, think of manually splitting wood, or shoveling snow, or any other tedious physically demanding job. You learn to rest when given the opportunity. Well plowing is steady work. It is a constant. They will learn to rest. Then as they stand better I will leave the plow in the ground and start walking around them petting them, rearranging their collars or forelocks (hair hanging down their foreheads) and they will learn it is a good thing for them to stand and me to come around to them. With the plow in the ground, they won't be as quick to get away as if it were a wheeled vehicle.
How's that Jim?
