Results 1 to 9 of 9
Thread: Maple Burl Thingy
    Nov 2010
    Sandia Park, NM
    98
    Maple Burl Thingy
    Viewing the works of the likes of Mike Foster, Vinnie Luciani and others too numerous to mention has made we want to do some "problem solving" turnings. I have a few in the works but this is the first one finished. I saw one similar to this on WOW, I think, but don't remember who turned it to give attribution to. The idea is to turn this flat topped "bowl" but leave the bottom natural. I also wanted the little legs to be placed a bit random and, my big accomplishment, I turned them entirely with a skew. The good news is, if I don't like it after a bit, I can through it back on the lathe and do something a bit more "traditional". Appreciate your thoughts, good and bad.
Name:	Maple Burl Thing Angle_edited-1.jpg
ID:	78079Click image for larger version.
Name:	Maple Burl Thing Side_edited-1.jpg
ID:	78081Click image for larger version.
Name:	Maple Burl Thing Bottom.jpg
    4,699
    ok so this is probably headslappingly obvious but how did you mount that to turn the bowl side?
    I'm surprised that it stands up right as well as it appears to with the legs so far to one side, am I missing something obvious there as well?
    I really like the bead, without that I think the bowl part would be lost with it it stands out visually. The way you have the second picture brings out the stalactite look nicely, that's a good shot.
    Nov 2010
    Sandia Park, NM
    98
    Thanks Ryan, there is a third foot in the foreground, don't know if you caught it? I have a "pronged" face plate I held the back with and made VERY light cuts
    4,699
    Quote Originally Posted by Nate Davey View Post
    I did, I suspect it may just be perspective the more I look at it, but it appears to be off center on the same side as the other two...
    Interesting, I'll bet light cuts!! If you happen to take a pic of the faceplate at some point it would be interesting to see.
    Nov 2010
    Sandia Park, NM
    98
    I'll get a shot for you, I purposefully made the legs asymmetric. Kind of keeping with the jagged look of the bottom
    30,017
    Very cool, Nate. I did a similar piece out of mallee burl a few years ago, but I bored a shallow hole with a Forstner bit to make a recess I could expand the chuck jaws into. After turning the bowl, I made a simple pedestal base that filled the recess on the bottom. I understand the pronged faceplate, but did you use the tailstock to keep the blank attached to it, or drive the prongs in somehow?
    Nov 2010
    Sandia Park, NM
    98
    Vaughn, yes, used the tale stock to hold the piece against the prongs then turned the bowl down to all but a little nub.....then sanded vigorously
    Jan 2011
    3,798
    That's an awesome chunk of wood. Great job!
    Goodland, Kansas
    4,834
    That is a beauty Nate. Love the wood.
    Bernie W.
  1. Maple burl NE HF
    Last Post: 12-31-2011, 02:39 AM
  2. More maple burl
    Last Post: 09-09-2011, 10:34 PM
  3. Maple burl box
    Last Post: 05-30-2011, 02:24 PM
  4. Replies: 12
    Last Post: 04-07-2008, 04:33 PM
  5. Maple Burl HF
    Last Post: 03-15-2008, 09:40 AM
