Results 1 to 3 of 3
Thread: Take Time for Maintenance, Avoid Costly Repairs
    A reminder to take time now and then for routine maintenance. I was overdue on checking the gear oil on my planer. I assumed I might have to top it off just a bit but, it was down quite a bit relative to the reservoir size. The planer does not leak oil per-se. There is a film which appears around the seals and gets covered in sawdust which gets removed through use of the machine. No puddles, no drips to wipe away. It is not enough that I would break the gearbox down to replace the seals but, I do try to check it 2 - 3 times per year. Take care of your machines and enjoy them for a long, long time.
    Dec 2008
    Santa Claus, In
    4,779
    Yep and don't forget to drain the air compressor as well
    4,552
    Yep to both
    A Turn N Time
    Frog Pond Guitars
  1. Cabinet Door Repairs
    By Darren Wright in forum Flatwork Project Showcase
    Last Post: 12-07-2015, 03:33 PM
  2. The least costly most expensive
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 05-30-2013, 01:28 PM
  3. Glass Repairs
    Last Post: 06-28-2011, 02:04 AM
  4. Siding repairs
    By Darren Wright in forum Carpentry and Construction
    Last Post: 08-08-2010, 05:35 PM
  5. costly error, bostich vs. porter cable
    Last Post: 04-10-2008, 11:03 PM
