Results 1 to 10 of 12
Thread: Bird House To DP Expansion Table
    Dec 2012
    Bedford, NH
    1,683
    Haven't worked much in the shop, mostly trying to get it set up for a winter past time hobby, or wood working repairs. My last project was an obscenely colored bird house which I have since changed to a more subtle color scheme. The birds still are boycotting it. Oh well!
    Now I've just completed another simple project, a Drill Press Expansion Table, that is well beneath your skills, but it passes the time & is enjoyable.
    I occasionally find myself having to drill pieces that are longer, sometimes much longer, than the table of my small drill press & have to use a roller support. So, when I ran across an article in a Woodsmith magazine, I saw a solution; a flexible expansion table.
    I decided not to glue the hardboard to the top of the table, preferring instead to screw it together so it could be removed if ever needed.
    I also decided against incorporating the T-Track, as I prefer (at least for now) to use a fence that is pinned with a 1/4" dowel pin and pivots, then clamped, to establish a uniform row of holes for drilling. Several dowel holes along the edge of the table & the fence allow positioning that will accommodate most any size/shape work-piece. Click image for larger version.
Name:	DP Exp Table-6.jpg
ID:	78195Click image for larger version.
Name:	DP Exp Table-4.jpg
ID:	78196Click image for larger version.
Name:	DP Exp Table-10.jpg
ID:	78189Click image for larger version.
Name:	DP Exp Table-11.jpg
ID:	78194Click image for larger version.
Name:	DP Exp Table-14.jpg
ID:	78193Click image for larger version.
Name:	DP Exp Table-16.jpg
ID:	78192Click image for larger version.
Name:	DP Exp Table-19.jpg
ID:	78191Click image for larger version.
Name:	DP Exp Table-23.jpg
ID:	78190If anyone is interested I can email the Woodsmith plans.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    10,600
    That is a really neat idea. Great job as well
    Jun 2007
    4,944
    A large, well designed DP table is a true joy! Especially when it is designed to work for what YOU do.
    Enjoy,
    JimB
    VOTING MEMBER
    Feb 2012
    2,746
    Great job! I really like the extension. I fastened my DP table down the same way, even though the plans called for clamps.
    Cheers,
    Roger
    You are gong to enjoy that. Great execution on those extensions.
    30,002
    Looks great, Al. You should get lots of use out of that.
    12,243
    Re: Bird House To DP Expansion Table
    Very nice Al. Still an item i need to add to my Dp. You got me thinking. :thumbup:
    Sent from my MB860 using Tapatalk 2
    3,134
    Great looking DP table Al. Now you can build that Bird Condo.
    Dec 2012
    Bedford, NH
    1,683
    That was so good!
    However, it would take some higher authority to convince me to build a bird condo.............maybe my wife!
    Constantine, MI
    7,887
    Well done
    www.wrworkshop.com
  1. Composite bird house...
    By John Pollman in forum Flatwork Project Showcase
    Last Post: 08-22-2013, 02:38 PM
  2. Now This is a Bird House
    By Al Launier in forum General Woodworking Q&A
    Last Post: 03-19-2013, 06:16 PM
  3. bird house for the fair
    Last Post: 07-15-2012, 07:51 PM
  4. Bird house bird suppliers??
    By Drew Watson in forum Off Topic Discussion
    Last Post: 01-08-2011, 11:09 PM
  5. BIGGER BIRD HOUSE
    By Paul Douglass in forum Lathe Project Showcase
    Last Post: 11-07-2010, 11:22 PM
