Results 1 to 10 of 19
Thread: Glenn - A bevy of bright beautiful Bessy's
    Constantine, MI
    7,887
    Hello, my name is Rennie, and I can be a slob.
    (you all say) Hello Rennie.
    Time, once again I'm embarrassed to say , to take a day and clean the shop. More importantly, to clean my clamps. Yes, I have a problem. I have glue on my Bessy's.
    I've been looking round on the web for a solvent to use on PSA glue. Lots of advice on solvents (alcohol, vinegar, etc) but none state specifically that they will work on PSA wood glue. I've tried a heat gun and dental picks - it works, but man is that slow!
    I'm sure there are other glue slobs here to be found, if they can be convinced to step forward. How do you deal with this?
    www.wrworkshop.com
    Well of course I had to go straight for the bait .
    P.s. The nice thing about Besseys is that they use a screw and teeth to catch so, you can wax them if you run out of blue tape.
    Thomasville, GA
    5,987
    Acetone will work if the glue has hardened. I've read that steam will soften PVA also.
    I did a 'duh' the other day and left a putty knife sitting after using it to scrape TBII out of some corners. The next day, the glue was nicely cured! I had to wrap a bit of paper towel over the metal part of the putty knife and let the acetone sit for a few minutes, then the glue came right off.
    Bill Arnold
    Constantine, MI
    7,887
    Glenn Bradley - DON'T Read this!
    I got to Bill's post little late so I went out and purchased some goof off. It seems to soften the glue very nicely. That and a Dremel tool with an abrasive wheel seem to do a great job of cleaning things up.
    Here are some before and after shots. To apply the goof offl I tightly wrapped a shop paper towel around the clamp and then soaked it. I let it soak for about 10 minutes. The abrasive buff works without the goof off but it tends to melt the glue and then it Is harder to remove.
    www.wrworkshop.com
    4,551
    Rennie when I had my shop I had a Taylor glue wheel and I had some stuff that would remove glue build up. Problem is I can't remember where I got it but you might snoop around there site and find something or they might point you in the right direction.
    A Turn N Time
    Frog Pond Guitars
    30,002
    Wow, the Goof-Off looks like it worked great. I've used white vinegar to soften Titebond, but haven't tried it on my clamps. I don't have enough glue built up on the clamps yet to cause me to take action on them. (I typically put a strip of wax paper over any parts of the clamps that are subject to glue drips, but still have gotten a bit of glue on them over time.)
    Constantine, MI
    7,887
    Turns out the Dremel tool may have been a little bit of overkill. This one was done with a red Scotch-Brite dipped in goof off. Worked Quite well
    www.wrworkshop.com
    12,243
    Re: Glenn - A bevy of bright beautiful Bessy's
    Well done Rennie, looks like i got a trip to make to HD while here. I saw duct tape mentioned on the can.
    Sent from my MB860 using Tapatalk 2
    10,600
    That worked great !!
    So, Xylene is the death-threat for gooped up clamps. Wunderbar! I've got some Toluene that I keep around to thin certain things. I'll have to give that a shot. Obviously proper ventilation when working with these nasties .
  1. Beautiful wood needs a beautiful finish
    Last Post: 04-14-2016, 02:45 AM
  2. New coping sled, thanks Bessy
    By larry merlau in forum Jigs and Fixtures
    Last Post: 12-13-2012, 01:08 AM
  3. A bevy of swifts.
    By Ryan Mooney in forum Flatwork Project Showcase
    Last Post: 10-03-2012, 03:07 AM
  4. Bright idea
    By Ken Cook in forum Lathe Project Showcase
    Last Post: 05-14-2011, 05:00 PM
  5. BESSY knows the definition!!
    Last Post: 02-13-2011, 02:30 AM
