glenn bradley
- SoCal
Coming along nicely. I also experience tearout or blowout when working QSWO if I am not extremely diligent. The same figure that makes it so beautiful makes it a bit troublesome to work.
Looking good, Rennie. I hope you don't mind that I took the liberty of editing your post to fix the pictures.
Then I attached the template with some double stick tape and used a 1/4" carbide spiral pattern bit in the router table. After just a little fine tuning with a file...Success!
Tomorrow I'm heading over to the stained glass supplier and pick up what I need for the little window in the door. A new experience for me!
Thanks! I found out after this was posted that my template shifted (or I didn't set it square) and the points were not square to the edges of the door. Fortunately I had cut the door a bit over-sized so I needed only figure out how far I was off (1/32" over the length of the door) cut one side in a taper, rip the other side parallel, then trim the ends square. Whew, another catastrophe averted!That came out great!
Punky? The wood I traveled all the way to Michigan to buy? From a trusted source?!?! Perish the thought!Rennie is that QS Oak old or punky? It looks it from the way it came out the forstner bit and the image of it in the hinge cut. Looks to me like to got the cut out perfect.
They were cut a bit proud on purpose and will be sanded flush.But i am confused with the dovetail joints in the picture that shows the cut out. Are the pins not supposed to be proud of the tails or do i have it the wrong way round. In earlier images you posted they were proud was that just a specific view?
The final cutout for the dial was done using a hardboard template and a patternbit mounted in the router table. I used a small diameter bit (1/4") so I would not have to do a lot of clean up to make my points sharp.When you say you cut the second cut out using a router bit, did you just free hand it with the pattern stuck on as a guide?
The finish I use is pretty simple and I'll detail it later. I actually think this clock might look great in cherry - and probably easier to build!I like the look of this clock. Wonder how it would look in some other woods. Maple for example with maybe some walnut highlights in places. BUt i do like mission oak very much, probably my favorite finish not that i can do that finish.
