Results 1 to 10 of 12
Thread: Ship's Ladder
    5,533
    Ship's Ladder
    Hi gang, Pardon the run-on paragraph... I'm pondering here at work for just a moment... I'm looking for a Plan for a ship's ladder/staircase. I want to get safer/easier access to the loft area of my shop. I can get up there on a ladder, but it is tough to haul things up/down from there if I'm hanging onto a ladder. I'd LIke to build a ship's ladder, hinged at the top... so that when not needed I can lift it up out of the way. Sketch when I can get around to it... sharing the design process, and probably in a year or so the build process...
    -Ned
    SE Minnesota
    2,526
    Ned, can you find a photo of something like what you're thinking of? Do you want hand rails on the side?
    Dec 2008
    falcon heights, minnesota
    5,610
    are you thinking of one of those folding stair items, the kind used to get into attics?
    benedictione omnes bene
    www.burroviejowoodworking.com
    5,533
    hi guys...
    Here you go:
ID:	78426Click image for larger version.
    think really steep staircase... where you 'have to' alternate steps as you go up/down. I would have a railing of some sort, OR i'll build it along the wall.
    Leaning toward a handrail, or simply mounting it where I can easily reach the wall (not hard to do in my shop...).
    I really like the open three main boards and steps between designs... I figure those would be easiest to build, and a simple hinge arrangement at the top, where gravity would lock it down solidly as I walked up it.
    I'm also seriously considering some sort of shop-grade Tansu storage cabinets/stairs.
    I'm thinking something like this, only using shop grade materials. Lots of shorts/lumber storage under there, no? Also, I want to do away with the Long lumber storage, or at least some of it, so I wouldn't mind putting that along the SE corner of the shop.
    Here is a traditional Tansu chest, beautiful in its utilitarian roots. Now that is something I could aspire to build for a home, but nothing that fancy in the shop.
    Here's one that just kicked the tansu up a notch in the 'might build' category:
    -Ned
    SE Minnesota
    2,526
    If you've got space for a fixed stair/tansu case, I'd do that because you'd get more storage that way. You could also make space under some of it for a machine on wheels or perhaps a small desk for working on plans or whatever.
    The ladder with the alternating steps would be handy if you have to fold it up and get it out of the way but you might find it makes more sense to buy a folding attic ladder and git 'er dun.
    5,533
    Quote Originally Posted by Dave Richards View Post
    Dave,
    mostly good points...with one exception...
    I've been up those folding monstrosities... and as stout as I am... I always felt like they were about to fold up, whimper and die when I was on them. I'm thinking 2x8's and/or ash 5/4 with routed out slots for the treads.
    -Ned
    SE Minnesota
    2,526
    Ah. Well. Understood.
    Then as I said, if you have room for a fixed staircase--even if it is steep--you should go that route.
    5,533
    found a great example of what I'm thinking of... a real Ship's Ladder
    -Ned
    Toronto, Canada
    276
    Looks like somecat found a rat.
    SE Minnesota
    2,526
    Ned,
    Would something like this help? It's not as fancy as the one you show but you could make it fancier.
    Also, this.
  1. How often do I use my ladder?
    By Frank Fusco in forum Safety Tips
    Last Post: 09-24-2016, 10:04 PM
  2. Step Ladder
    Last Post: 06-12-2015, 03:53 PM
  3. How do you ship?
    Last Post: 09-06-2013, 03:37 AM
  4. Raised bed ladder
    By Chris Hatfield in forum Flatwork Project Showcase
    Last Post: 03-01-2011, 05:24 AM
