Results 1 to 7 of 7
Thread: primer over silicon sealent?
    17,471
    i have made 3 windows and sealed the glass with silicon, as well as the outside edges where water could seep in, well i tried using some kilz for the primer and its water base and just beads up on the silicon areas so what can use to cover this for a primer? would oil base kilz do it, i tried to seal it with shellac first and then the water base and same trouble. can i just spray it with a lacquer base paint then cover that with the final color later?
    Nov 2012
    Wapakoneta, OH
    611
    I'm not sure if anything will stick to the sealant, but if something does...it would be shellac. Since that didn't work (the shellac) I'm doubtful you will be able to coat it with anything. One thing that might work would be to cover the existing silicone with another layer, but use the "paintable" kind, some of them are labeled silicone. Then paint that. To be honest I doubt this will work, but the only thing I can think of.
    5,320
    Nuthin' sticks to silicone! There's no paint, sealant, primer that will stick to it.
    Shoulda used the 'paintable silicone' stuff!
    Jun 2007
    4,944
    My money must be made of silicone---I sure cannot get it to stick in my billfold.
    Enjoy,
    JimB
    VOTING MEMBER
    I believe Jim D. is right. You might check a D.I.Y. forum and see if anyone has come up with a workaround.
    NH
    4,005
    As said above nothing sticks to silicone and the same goes for silicone it sticks to nothing. If you have the time to wait until it has cured pull it off and redo with a paintable caulk. My go to would be Proflex
    Stupid hurts.
    3,132
  1. Excellent Primer on Planing Square
    By Bill Satko in forum Neander Woodworking Q&A
    Last Post: 09-13-2012, 02:37 PM
  2. Do I HAVE to paint over primer?
    By Tom Baugues in forum Finishing School
    Last Post: 11-13-2011, 11:47 PM
  3. Silicon Valley, today there really is such thing as a free lunch
    By Alan DuBoff in forum Off Topic Discussion
    Last Post: 01-19-2008, 07:10 PM
