Results 1 to 3 of 3
Thread: Mr. Clean Magic Eraser for woodworking?
    I was talking with a coworker today about a current project and he asked me if a Mr Clean Magic Eraser could be used between and after coats of poly. Does anyone do this?
    So mote it be.
    http://www.SCAregalia.com - Masonic regalia and supply
    Save 10% with the code: BROTHER
    I've used a Magic Eraser a lot for removing pencil marks from painted walls (carried one in the tool belt when I was installing artwork a couple of years ago), but I don't think it's abrasive enough to scratch poly. The whole reason for sanding between coats of poly is to put minute scratches in the finish and provide "tooth" for the next coat to adhere to. I doubt the Magic Eraser would do that.
    That said, it might work for removing any dust nibs (bumps) left in the final coat of finish. Shouldn't hurt to try. I'd wet the Magic Eraser first, then wring it out well before rubbing on the finish.
    Santa Rosa, CA
    138
    I have friends that use ME to clean their acrylic aquariums. If it doesn't scratch acrylic, I don't think it will scratch poly.
  1. magic dollar magic trick
    Last Post: 09-16-2014, 07:38 PM
  2. bandsaw magic
    By Rich Soby in forum Off Topic Discussion
    Last Post: 08-19-2011, 06:02 AM
  3. It's Magic
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 06-16-2011, 03:33 PM
  4. LRH magic molder??
    Last Post: 07-23-2010, 01:12 PM
  5. Magic
    By Jim C Bradley in forum Off Topic Discussion
    Last Post: 07-13-2010, 01:08 PM
