Results 1 to 3 of 3
Thread: Plumber Question
    Jun 2007
    4,944
    Plumber Question
    When you get old your brains leak out. Therefore I cannot quite remember how to do something I have done several times before.
    QUESTION: When you drain the water out of the system to get rid of "knock" what do you do about the hot water tank? Ignore it? Turn it off and drain it also? Other?
    I know to turn off the water, open the faucet in the highest part of the plumbing system, drain from the faucet in the lowest part of the plumbing system.
    Thanks in advance!!!
    Enjoy,
    JimB
    VOTING MEMBER
    Rochester Hills, MI
    940
    Here's the procedure Jim. It's easy!
    http://masterhandyman.com/askglenndetails.cfm?id=195
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten"
    Jun 2007
    4,944
    Thanks ten million John. (You got a good deal here. I said, "Thanks a million John." before. However, I got an error message saying that the message was too short. So I upped the ante to Ten Million to get a longer message.)
    I hope that gave you a chuckle.
    Enjoy,
    JimB
    VOTING MEMBER
  1. Hi, I Need a Plumber Friend
    By Jim C Bradley in forum Off Topic Discussion
    Last Post: 10-07-2011, 03:44 AM
  2. Don't have your plumber hook up your dust collector
    Last Post: 06-18-2011, 04:01 AM
  3. Stu The Plumber....
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 08-07-2010, 10:02 AM
