Results 1 to 4 of 4
Thread: 10" blades for CS
    Sep 2007
    Central (upstate) NY
    1,457
    10" blades for CS
    I resisted the urge to hijack the TS blade thread. After we sell the old house and pay off a bunch of debts I might someday have a leisure tool budget (I do have a plumbing tool budget, but plumbing is not a leisure activity). I enjoy using my EZ Smart system, but sometimes 7 1/4" is just shy of what I want to cut, so I am thinking about getting a 10" CS someday for use with the EZ Smart rails.
    I know that with my RAS, I need to be very aware of using positive hook greater than 10 degrees or so for pull cuts, as blade climb may result with poor technique.
    For a handheld circular saw, especially on a rail, are there any types of blades to avoid for safety reasons? It seems like [what, on a TS, would be called] a kickback event would simply bog the blade, right?
    Is the TS blade discussion simply also relevant for handheld CSs?
    Rochester
    846
    Hi Mark! Good question. The same laws of physics apply, in that more teeth tends to equate to a cleaner cut, but also more resistance and heat. I'd guess that the same angles that are appropriate for a TS are also appropriate for a CS. Be sure the blade kerf is compatible with any splitter or riving knife that might come with your CS.
    Got Wood?
    Quote Originally Posted by Mark Kosmowski View Post
    If you've never experienced kickback from a powerful handheld circular saw, I recommend you pass . Binding or misguided cuts will stall the blade on lower powered saws but, kickback is very real on circular saws (and jointers for that matter), just not as well published as the result is usually just a bruised set of hand/arm/shoulder muscles along with your pride.
    As to blade choice, I would look into the geometry used on circular hand held beam saws. I would think this might port-over to what you are wanting to do.
    17,471
    i can attest to not wanting a larger circular saw, mark. you should do your croscutting with a normal circular saw or your RAS, your pride and fingers or body will be glad you did.
  1. Avanti Pro 10" Blades
    By Dan Mooney in forum Hot Deals
    Last Post: 03-11-2011, 02:55 PM
  2. SOLD : CMT 10" Saw Blades
    By scott spencer in forum Old Ads
    Last Post: 04-25-2010, 12:20 PM
  3. FS -- 10 and 12" Blades for Table Saw and CMS
    By Mark Rios in forum Old Ads
    Last Post: 11-11-2008, 07:26 AM
  4. Replies: 1
    Last Post: 07-16-2008, 11:21 AM
  5. "Underpowered" Table Saw Blades
    Last Post: 08-04-2007, 09:53 PM
