Results 1 to 10 of 23
Thread: question about inlace acrylester
    new york city burbs
    10,188
    I got in my bottle stopper chuck so I decided to make a practice stopper.
    Used some scrap walnut I had glued up.
    drilled the 23/64 hole as instructions said, the first stopper came off chuck, couldn't finish.
    second stopper, I used a 21/64 bit, fit tight, was able to finish it, but I wont use it, didn't sand it good, too boring.
    before I drill some inlace acrylester, any suggestions as to what size bit? instrustions say 23/64(niles and psi stoppers)
    Human Test Dummy
    North West Indiana
    6,099
    When you say it came off of the chuck, how do you mean this? It flew off and hit the wall? Unthreaded itself? Stripped its threads while you were turning it?
    I don't have my set handy, but I do have a drill bit and a tap so I cut good threads in not just relying on the threads of the chuck to cut them. Then if the wood has any spalting or punking going on after cutting the threads I apply general amounts of thin glue, allow to dry and then recut the threads and have had success that way.
    Jon
    Jul 2007
    DSM, IA
    5,719
    Quote Originally Posted by Jonathan Shively View Post
    I do the same as Jonathan.
    My Website
    Me three. I use a tap before putting the blank on the chuck. For your case Allen, I'd suggest drilling the hole with the smaller 21/64" bit, then using a tap to cut threads in the plastic. If it seems too tight for the tap, then I'd go to the bigger drill bit.
    new york city burbs
    10,188
    stripped its threads while on the chuck.
    Human Test Dummy
    new york city burbs
    10,188
    well, the wife has a house full of women tonight, so I decided at 7 to go out and try a stopper with this stuff.
    The threads worked out fine. it held tight, and I had to use a wrench to screw it in the last few turns.
    Ofcourse, Im ashamed to display my work, it was pretty much a disaster, as turning this stuff for me wasn't easy at all, and I had chip outs I couldn't repair with sanding.
    My biggest mistake, an unforgiving one, is that I must have drilled the blank a couple of degrees off, so when I screwed in the stopper, it didn't go in straight, and doesn't sit flush all the way around.
    So that and the chip outs, well, I failed. plain and simple.
    The instructions say not to use carbide tips, but I don't work skews well, and the entire body of the piece came out without chip outs, it was only the top, maybe Im doing something wrong.
    Tough to tell from the pictures.
    I wont toss it, Ill keep it for my house when I have an open bottle, no one will notice but its good to remind myself to do better.
    The glue set and I couldn't unscrew it, but for the 3.50 the stopper cost, eh.
    Human Test Dummy
    S E Washington State
    3,777
    I use the Ruth Niles chuck and also her short bite she sales. Never had a problem, on soft wood I do the CA the threads thing mentioned above. I drill on the lathe.
    "We the People ......"
    Aug 2008
    Reno, Nv
    3,632
    Inlace is a problem for experienced pen turners. Personally I won't use it if the same things can be found in PR. Have a shot with a 3/8...see if it's closer. IA doesn't do well with a lot of curves, must be turned with stupid sharp stuff and very light cuts. I can pull an 1/8 off a resin blank at a shot with a skew but IA...maybe 1/32". Those stoppers are chrome plated brass and will pit and "rot" in a really short time if used on a regular basis.
    Seeing you were able to get clean cuts on the sides but not on the end, I suspect the chipout problem on the end was at least partially due to vibration. Since the base of the blank was not sitting flush on the chuck (or mandrel), the blank would be prone to vibrate when working on the end of it. Even though you may not be satisfied with the results, you still walked away with more knowledge that you started with, and you know the next one will be better because of it.
    Dec 2008
    falcon heights, minnesota
    5,610
    i find that i have 2 problems when turning stoppers, thread tear out, and having the darned chuck come loose.
    benedictione omnes bene
    www.burroviejowoodworking.com
  1. Using/Buying Inlace, Stone Inlay or Other Fill-In Material
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 04-14-2014, 06:30 PM
  2. Inlace Acrylester Sierra Pen
    By James Lord in forum Lathe Project Showcase
    Last Post: 06-01-2011, 01:45 PM
