Results 1 to 10 of 22
Thread: Need advice for finishing basswood craftwood
    If anyone can offer some advice it would be greatly appreciated.
    I am an artist and I'm trying to make novelty boards. I take craft basswood and cut it into shapes, paint the wood with Behr flat black paint, and then use decoupage to glue my art prints onto the wood.
    After waiting 24 hours for the paint and decoupage to dry, I brush on a thin coat of Minwax water based polyurethane. I coat one side and wait 3 hours before coating the back. I then let the wood sit for 3 days to dry. After 3 days the poly appears to be firm, shiny, and no figure prints appear in the finish. Everything looks good.....until....
    I took the boards and put them inside small clear plastic bags to protect them. I had them sitting inside the house on the table for about 2 weeks. I pulled one of the boards out to look at it and the poly was marked up and dull where it made contact with the plastic. I checked the other boards and they all had the same problem.
    I don't understand why that happened. I followed the directions and waited way longer than the recommended drying time. Is there a cost effective clear that I can brush onto the boards? I just need something to stay firm to protect the wood and artwork, offer some minimal UV protection, and survive sitting in a plastic package. My goal was to eventually sell these, but I can't now.
    I chose brush method because I didn't like the texture that spray cans made. I don't want to sand if I don't have to. Brush strokes are OK.
    Thank you in advance.
    Matt
    30,015
    Welcome to the forum, Matt. It sounds to me like the poly on your boards was not fully cured, despite the appearance. Without knowing your location, my guess is that the humidity in your area caused the water-based finish to cure more slowly than usual. I'll let some of the finish experts here chime in, but I suspect you might have better results with a solvent-based finish.
    Thank you for responding Vaughn. I live in Phoenix AZ. The temps are between 103-106 degrees with low or no humidity. Not fully cured was my guess as well...just wasn't sure. The directions on the can is kind of misleading.
    Unfortunately I can't wait 30+ days for for each side to cure. I was thinking maybe an epoxy or a clear that uses a catalyst to make it cure faster and harder, or something like Zinsser Shellac? I don't think I need anything super industrial. I'm such a complete noob when it comes to clear coats. I only tried the Minwax because I figured it was a lesser evil when it comes to fumes and the environment. Fumes really bother me even when wearing a respirator. But at this point I'm willing to try something else. Do you think the existing boards are salvageable? Like sand them a little, re-coat, and then let them sit for a month to cure? All I know is I refuse to sell any of my boards until its done correctly.
    Thank you again and any suggestions are welcomed and appreciated.
    Apr 2009
    Outside the beltway
    5,255
    How about a shellac thinned 50/50 for 3 coats and then desired finish thin coat brushed out then full coat.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    12,256
    Re: Need advice for finishing basswood craftwood
    My thoughts are is there any chance that your decoupage was still moist internally and when u bagged it, it came out and upset the top coat?
    If i understand correctly you decoupaged over the bass wood. Well bass wood is low density soft and i imagine pretty porous. Should u not consider sealing the basswood on its own first then put the decoupage down and make sure it has dried properly then topcoat.
    I dunno but this is how i see it. The bass wood could have absorbed water from the decoupage then its gotta go somewhere when you sweat it in the plastic bag.????Just my wild imagination.
    Have you tried to recreate the problem without any fancy artwork just process samples for each stage and then change one thing up at a time.
    Sent from my MB860 using Tapatalk 2
    Thank you Dave & Rob for the replies.
    Dave, I might have to try brush on shellac. I tried Zinsser spray shellac but it left the boards kind of pitted. I'm trying to figure out a process to produce a lot of boards. There's no way I'd be able to hand make and sand that many boards too. When I brush the poly on its pretty smooth eliminating the need to sand.
    Rob, the boards are only 4.5" x. 3.25" in size. The artwork is the exact size as the board and I only put just enough decopauge on the back of the artwork in order to glue it to the painted wood. I don't put decopauge over the top of the artwork or anywhere else on the board because it has a tendancy to flake off along with any poly. I let the decoupage sit for several hours before doing anything else. I did brush the Minwax over the entire board including the artwork to seal everything up.
    I haven't tried putting the poly onto a blank board, letting it dry and putting inside the bag. Its a test I need to try to rule out the Minwax or the Behr paint.
    I think your onto something when you say something might be sweating when the board is in the bag. When you look at the bagged board it looks like its moist in the bag and as if the bag has stuck to the board. When you pull the board out of the bag, both the board and bag are dry....but where the bag touched the board the finish is dull and you can see a pattern where it touched. The rest of the board is glossy.
    I'll take some pictures and post them here shortly.
    Thank you again for the responses.
    The board in the bag. You can see how it looks like the bag is stuck...but its not.
    The board removed from the bag. You can see where the bag touched the board.
    A board never placed in a bag and has been sitting on the table for a week. No marks.
    Sorry the pictures aren't that great but it shows what I'm trying to explain.
    12,256
    Dave Hawksford please take a look. Something very wrong on the go here but its over my head.
    Looks to me like u got something on the board in the first place thats causing orange peal effect. So i think you should show us a pic of the board itself blank to start with. Are u sure this wood is basswood and oil free. Looks to my pea brain like some residue or something is on the board even before you paint it.
    What paint did u use. You should not have orange peal looking finish.
    By the way...if u wanting to do production of this kind of thing, think of spray application. You dont need to use the rattle can approach. With a small gun and a "nail gun" type pancake compressor you can do a pretty good job of spraying water based coatings...thats how i do my covering.
    If things take off then you can always upgrade to a big compressor.
    The thing is this form of application will give you a better finish.
    But its not going to fix your immediate problem.
    You got something going on with that board that says to me one coating dont like the other and is dimpling. So fix that before any further process steps.
    Hey Rob thank you for all your feedback. I very much appreciate your advice. I finally found the answer to my problem.
    I'm using Revell model building basswood. Even though its already sanded smooth, when I paint it with the Behr paint the wood absorbs moisture and the fibers expand. Which is OK. I don't mind and actually want the wood grain texture....not a glass smooth finish.
    I've been doing things correctly and waiting the proper dry times during each process. What's destroying the project is the plastic bag I package the board into. Even though the board appears dry, the plastic reacts with the poly finish and draws out moisture trapped in the wood fibers messing up the finish.
    The guy I spoke with said I'd get the same result even if I used automotive clear. Its just an issue with the plastic. He recommended using a lacquer finish because it will dry much faster than water based poly and then said to wrap the boards in thin sheets of parchment paper to prevent contact with the plastic, which makes sense because when you buy wood items such as a desk or whatnot, its always wrapped in thin paper and then wrapped in plastic. So I need to rethink the packaging.
    12,256
    I dont think that wood u using is basswood its probably balsa wood which is even more porous. Is it very very light in weight because then its definitely balsa wood. Thats typically what is used in model kits etc.
    Also just considering your overall goals buying wood where its been packaged and branded and gone through a distribution chain to the point of buying it at a craft hobby store....well your input cost is going to be very high. So you might consider finding a different source like getting wood direct from a lumber yard that provides what is called DS4 wood meaning dimensioned and surfaced 4 sides. Some would even cut to size for u.
  1. Emergency Box Finishing Advice Needed
    By Cynthia White in forum Finishing School
    Last Post: 03-29-2011, 11:38 PM
  2. Easy Beginner Finishing Advice Needed
    Last Post: 11-11-2010, 05:44 PM
  3. OK, now what! (Veenering/finishing advice please)
    By Jeff Bergman in forum General Woodworking Q&A
    Last Post: 02-10-2010, 07:27 PM
  4. Basswood?
    Last Post: 01-20-2009, 01:02 AM
  5. The Sad Basswood Saga
    By Travis Johnson in forum General Woodworking Q&A
    Last Post: 02-26-2008, 03:27 AM
