Results 1 to 6 of 6
Thread: Debarking live edge slab
    Sep 2013
    Toronto, Ontario Canada
    31
    Hi guys,
    Im working with some walnut live edge and want to debark the live edge. I'm currently using a chisel but its slow going and i will have to do alot of sanding to get to the sapwood. Any tips?
    4,698
    Careful use of a draw knife. Then a wire wheel on the angle grinder. You'll still have to do a distressing amount of sanding. A flap sander on the grinder or ros might help some in the less detailed spots. Definitely a face mask with the wire wheel, it throws a ton of nasty dust when using it to debark.
    As Ryan suggests, be sure to use a dust mask. Walnut can be a wonderful source of allergic responses, at least it is for me.
    Sep 2013
    31
    I managed with a bigger chisel and a sander
    Used a mask
    Honolulu, Hawaii
    1,103
    An angle grinder with a "Lancelot" wheel, AND a guard. The Lancelot is a wheel made to fit the grinder spindle, with a chainsaw band around it. (that is why the guard is required) A side handle on the grinder is needed as well, for best control. Cuts as aggressively as you want it to, from lightly to deep cutting. ALWAYS wear a full face shield and a good dust mask, and be sure to seal it around your nose too. (I have seen people wearing masks below their nose. Lot of good that does them)
    Ah,,,to live in Paradise!
    Registered voting member
    4,698
    Quote Originally Posted by Tony Baideme View Post
    And keep both hands on the grinder until it's spun down.... Ask me how I know (no digits were lost but I wasn't sure for a few minutes and I only have a fingernail by the grace of about 1/100 of an inch although it's about 1/4" longer on that finger now than its partner). Really takes the wood of though
  1. How to plane/flatten large live edge boards bigger than 20"
    By Sam Keays in forum General Woodworking Q&A
    Last Post: 06-01-2015, 01:55 PM
  2. How to dry live edge?
    By David Agnew in forum General Woodworking Q&A
    Last Post: 03-19-2015, 02:20 AM
  3. Live edge table opinions please
    By Alan Bienlein in forum Flatwork Project Showcase
    Last Post: 12-09-2013, 01:55 PM
  4. Working on live-edge walnut, have some questions
    By Mike Frencel in forum General Woodworking Q&A
    Last Post: 09-23-2013, 11:29 PM
  5. A Small Live Edge Wall Case
    Last Post: 01-27-2013, 11:19 AM
