Results 1 to 10 of 16
Thread: two part epoxy over tung oil
    Sep 2013
    Toronto, Ontario Canada
    31
    Hi guys,
    So i'm working with some walnut and 100% tung oil. I'm on my 2nd coat and really love the look of it when it has a nice film of oil before it's wiped and dried. I was wondering if you can finish over tung oil with 2 part epoxy as it gives the look i'm looking for. I understand that the oil needs to breath to cure. I was wondering if anyone has every tried it and how long should I wait after the last coat to apply the epoxy?
    Note that i live in canada and we started running the furnace so its really dry in my house
    5,317
    I'd wait at least a month before top-coating with anything. Then, I'd start with a couple sealing coats of shellac, and let them cure for several days before putting anything else on it.
    I wouldn't use the epoxy, mainly because it's so hard to repair. Instead, I'd use something like Behlen's "Rock Hard" finish, or a varnish.
    17,470
    another NO vote for the two part epoxy now, after using the tung oil.. adhesion troubles for sure.. that epoxy is better used as a stand alone finish rather than a top coat.. i also suggest the Behlen's "Rock Hard" finish.
    Sep 2013
    31
    Will Behlen's give me a similar looking finish? I watched some videos that say you can use a sanding sealer once the oil is cured and put whatever you want overtop the sealer after you sand it smooth.
    Also the Behlen's, what is the best way to apply it if you don;t have a spray gun?
    5,317
    Quote Originally Posted by Mike Frencel View Post
    The Behlen's will give a nice, deep-looking gloss finish when multiple coats are applied. Sand (or maroon Scotchbrite) the finish between coats, and apply maybe a coat a day for five days. Brushing is fine. That's the only way I've ever applied it. If you want less gloss, you can rub it down with scotchbrite, then wax it.
    30,002
    I'd wait at least a month before top-coating with anything. Then, I'd start with a couple sealing coats of shellac, and let them cure for several days before putting anything else on it...
    Seconded. At least a month, if not more. Also, you want to make sure it's dewaxed shellac.
    Sep 2013
    31
    Can you recommend a shellack product that i could buy at lee valley?
    12,243
    Mike Lee Valley offers raw shellac flakes that you would have to dissolve and make up your own. What most do is to buy Zinsser shellac available at home depot just make sure to get the dewaxed one as Vaughn has pointed out. Check that the tin actually has this mentioned on it.
    Austin, Texas
    1,447
    Zinsser is the primary vendor of pre-mixed shellac. They changed the name of their 2 pound cut dewaxed shellac to remove the name shellac, perhaps so only those with the secret password would know what it is and what to buy.
    If you want a 1 pound cut (for the first sealer coat, perhaps) mix 50/50 with denatured alcohol. If you want a heavier (final) coat, use out of the can. The brush will be near impossible to clean, but next time you need a shellac brush, put the hardened brush in shellac, and it will resoften for use.
    Last edited by Charlie Plesums; 09-25-2013 at 03:16 PM. Reason: correct spelling of Zinsser
    Charlie Plesums, Austin Texas
    12,243
    Re: two part epoxy over tung oil
    Charlie any chance you can fix your image so the secret gets revealed.
    Sent from my MB860 using Tapatalk 2
  1. ZCI Restore with Epoxy
    Last Post: 03-13-2015, 12:15 AM
  2. Replies: 17
    Last Post: 02-26-2014, 06:09 PM
  3. Liquid Plastic or 2 Part Epoxy Question
    By Mike Wagner in forum Finishing School
    Last Post: 05-31-2013, 01:58 PM
  4. What did the Epoxy say to his friends?
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 03-11-2012, 04:12 AM
  5. what epoxy?
    Last Post: 06-02-2010, 05:21 PM
