Results 1 to 10 of 11
Thread: sander woes-part two
    17,470
    well when i had peter here, we diagnosed the ROS sander that dies on me.. we have come to the conclusion that its the winding.. so here is what it does.. you start it up and winds up to speed ok. but as soom as you place on the wood it has no power, this is a 2 amp motor and the other one is a 1.7 amp motor and they both have alot of hours on them but the 1.7 actually has more as it was the first one here.. so you sparkies out there what gives a motor power and is this fixable? the armature and brushes look ok got a little blacking on the armature but peter said it was normal..
    Jan 2011
    3,798
    Larry, I don't believe it's a motor problem. The sanding pad rotation is free-floating. The sanders motor has no direct connection to make the sanding pad spin. The sander motor turns a counter-weight (eccentric housing), which the sanding pad is attached by a ball bearing (or bearings on some models). That bearing is mounted off-center to the axis of the counter-weight. As the motor rotates the counter-weight, the center of the sanding pad moves in a small circle around the axis of the counter-weight. The sanding pad is free to rotate on the ball-bearing, in reaction to friction created between the pad and the work piece. Some models also include a pad brake feature to limit maximum pad speed. This brake consists of an o-ring that provides resistance to pad rotation.
    I've fixed 2 different brands in the past by simply replacing the belt{actually an o-ring imo}, they stretch due to use &/or heat {usually caused by too much applied pressure during use}, and occasionally dust build-up on the ring can cause them to glaze over and allow slippage. Anyways take this with a grain of salt until those with more experience chime in.
    17,470
    well ken i have replaced the belt and the pad and it still wont work.. i will bring it along next time i am in your area, which looks like the wknd of the 7th. and you can see if yu can get it working..
    13,437
    Re: sander woes-part two
    Sorry Larry, What are the brands and models of the sanders?
    17,470
    darren its a pc333, the motor winds up and then wont have power..
    Jan 2011
    3,798
    I'd be glad to look at it for you Larry, if your antsy or bored you might also check out the lower bearing...part 11A here they have a tendency to freeze up and once in a while a good cleaning & lube will get things turning again...no, not that kind of turning
    12,247
    Isnt there a time when these things find themselves in the garbage bin.
    I see i nice refurbed Bosch in your future. Checkout CPO bosch
    http://www.cpotools.com/bosch-recond...efault,sc.html
    Their recond machines are good and cheap. $60 is the most expensive one and i think they having free shipping.
    Sent from my MB860 using Tapatalk 2
    17,470
    my problem rob isnt that i need to have this sander running its that i got paper for it and its brother i already have a couple bosch sanders that i use regulary but this sander is good for job site use..
    13,437
    The brushes look like they move ok in their slots? I've had grinders that would wind up and lose power, as the brushes were hanging up and not making full contact. Other than that, you'd need to test the coils on the armature with a meter to see if there is damaged windings...
    http://www.groschopp.com/how-to-check-a-motor-armature/
    17,470
    thanks darren, the brushes seem to move fine good length left and spring power, i am assuming it must have a bad armature.. will have to play sparky later
  1. Problem finding a part for Delta 18 x 36 Drum Sander
    By Gayl Beals in forum General Woodworking Q&A
    Last Post: 11-20-2015, 11:10 PM
  2. Replies: 17
    Last Post: 02-26-2014, 06:09 PM
  3. Planer woes AGAIN
    Last Post: 12-17-2012, 03:57 AM
  4. Truck woes
    Last Post: 09-02-2008, 06:09 PM
  5. DC woes
    By Jay Lock in forum General Woodworking Q&A
    Last Post: 01-17-2007, 05:25 PM
