Results 1 to 10 of 12
Thread: guess I read something wrong
    S E Washington State
    3,777
    I'm working on putting a finish on a spanish cedar cigar box. It is soft so I stained it and then planned on putting a coat or two of sanding sealer on it before the final finish. I read a couple tutorials on the internet about applying sanding sealer and they both said (I thought) to thin the sanding sealer with mineral spirit, 50/50. Well I tried that this AM and this is what I came up with. The more I stirred the thicker the glob got! Did wrong, or maybe something is wrong with my sanding sealer?
    "We the People ......"
    What kind of sanding sealer were you using? Lacquer or shellac based?
    3,777
    I really don't know. I had put into a smaller container do keep it better sealed after I had used half the original bottle. Which should I buy? I am thinking I will use shellac as the final finish.
    I hope that you are putting the sealer on the OUTSIDE of the box, if the Spanish Cedar is lining the box then you should leave the wood unfinished.
    The sanding sealer I use here in Japan is thinned with Lacquer Thinner.
    3,777
    Ha, went back and reread one of the tutorials I, clearly states lacquer thinner! I'm really getting OLD!
    4,552
    Yeah what Stu said unless its water base
    A Turn N Time
    Frog Pond Guitars
    3,777
    Looks like Shellac would NOT be the finish to use if the sealer is lacquer based, that correct? The sealer I had was Mylands.
    It looks like the Mylands sealer is lacquer-based, so lacquer thinner would be the way to go to thin it. For a final finish, I'd suggest staying with lacquer of some type, or just using the sealer alone.
    Is the outside of the box spanish cedar as well? I've never seen a humidor with a spanish cedar exterior, just always lined with it.
    3,777
    Quote Originally Posted by Justin A Smith View Post
    Justin it is a cigar box I am putting a finish on. Making a ukulele out of it.
  1. something wrong?????
    By John Ryan in forum Lathe Project Showcase
    Last Post: 09-09-2011, 06:31 PM
  2. If you do not like to LOL do not read
    Last Post: 12-04-2009, 03:42 PM
  3. how much can go wrong?
    By Frank Fusco in forum General Woodturning Q&A
    Last Post: 06-27-2008, 03:52 PM
  4. PLEASE READ THIS
    Last Post: 03-04-2008, 05:07 AM
