Results 1 to 6 of 6
Thread: Cradle build
    Feb 2012
    2,749
    Cradle build
    I wanted to make a cradle for my new grandson. I was hoping to send it up to Fort Mac by BPX, but I won't be ready in time, largely due to the pinched nerve in my back that's been slowing me down this week. I took a plan off the net, and made some modifications. I am using birch ply instead of building up panels from wood. I also took the canopy off the cradle for simplicity. I'll be using pine for the rockers, and will stain the whole thing with "Puritan Pine" finish from, uh, Minwax I think.
    The pictures show the main parts cut out, and a trial assembly I did today. i have to clean a few things up then put the box together and build and attach the rockers.
    One question: the rockers have a 28" radius curve on them, and the base of the cradle is 15" wide. Will the whole thing balance on the rockers on its own? What keeps it from flopping to one side or the other, especially with a baby inside it?
ID:	78683 Click image for larger version.
ID:	78684 Click image for larger version.
ID:	78685 Click image for larger version.
    Cheers,
    Roger
    WNY, Buffalo Area
    873
    Looks like you are off to a good start! Can't wait to see the finished product.
    I'm not sure on your question about the rockers. There is probably someone here who can help out.
    www.tinyurl.com/thewoodshoppe
    5,172
    Rocking chairs often have a reverse curve on the back end of the rocker to keep from rocking too far back. I have also seen a short reverse on cradle rockers to stop the 'rock' before dumping the baby out. FWIW
    Sep 2007
    Plainwell, Michigan
    4,857
    The ones I have made have a low center of gravity and sit well, even with an occupant. When you get the rockers on yours I believe you will notice the same and should not have an issue. Yours is looking good Roger and I am looking forward to see the finished cradle
    Feb 2012
    2,749
    I have now prepared the bed of the cradle for assembly and staining. Here is a picture of the sides and ends. I departed from the plans by using a dado joint and glue instead of the flush joint and screws called for. I am wondering whether to stain the inside parts first, and then assemble and finish it, or to just assemble it and stain the whole thing. Any suggestions appreciatiated.
    Cheers,
    Roger
    Feb 2012
    2,749
    While I am asking, should I use wood conditioner on this birch ply before staining, and also the pine rockers that I haven't cut yet? Thanks for any advice on this.
    Cheers,
    Roger
  1. Glider cradle
    By Tom Muellner in forum Flatwork Project Showcase
    Last Post: 05-21-2013, 10:32 PM
  2. cradle build
    Last Post: 06-18-2012, 01:14 AM
  3. Cradle Project
    By John French in forum Flatwork Project Showcase
    Last Post: 05-19-2012, 04:12 PM
  4. Toy cradle
    By Matt Ducar in forum Flatwork Project Showcase
    Last Post: 04-27-2011, 03:51 AM
  5. Cradle from new grandpa
    By Dave Trask in forum Flatwork Project Showcase
    Last Post: 12-24-2008, 11:24 PM
