Results 1 to 3 of 3
Thread: Tiny Tendons
    Mar 2009
    Lincoln AR
    142
    Tiny Tendons
    I'm building a steam engine model that requires me to drill some 1/2 x 1/4 mortise & tendons. the wood is 3/4 x3/4.
    I scribe a line in the center 5/16 half of 3/4 and I dilled two 1/4 holes. I then tried to cut off the excess with 1/4 bit in a colt router. It ended up to big. I was hard for me to tell wear the bit on the back side. I tried a smaller bit and still managed to rag it out.
    I'm not going to try square it on the mortise or tendons, so just looking for ideas. I like to make a pattern but there isn't way to get a bass follower that small that I know of. Any thoughts would be appreciated.
    12,256
    Bill why not use hand tools. Get chisels and use them to make the mortise. Just go carefully and gently.
    Alternatively get a 1/8" router bit. http://www.leevalley.com/en/Wood/pag...435,46171&ap=1 make a fixture and with aid of template rout it out. Use a palm router for the ability to hold it steady.
    Mar 2009
    Lincoln AR
    142
    I guess you got my creativeness going I have a HF mill. I put the wood pieces in the vice put 1 1/4 in router bit in the chuck measured the spacing and whala! perfect mortises. Thanks for your feed back.
  1. 8 tiny reindeer
    By Don Orr in forum Flatwork Project Showcase
    Last Post: 12-24-2012, 07:58 PM
  2. Tiny Woodworking
    Last Post: 03-13-2012, 09:45 PM
  3. Tiny Vix bits? AKA - How do you install tiny hinges . . .
    By Jim Mattheiss in forum General Woodworking Q&A
    Last Post: 03-02-2011, 01:58 PM
  4. Little tiny cracks
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 01-21-2011, 03:29 AM
  5. tiny saw blades
    Last Post: 02-09-2007, 12:54 AM
