Results 1 to 10 of 15
Thread: The ultimate accurate miter sled for a table saw?
    I have been struggling trying to make perfect 45º miters on the corners of some boxes.
    My oldest son's FIL gave me the walnut a couple years ago and it's been sitting in my shop. I began trying to make some keepsake/jewelry boxes from the wood for my DIL and her mother a month or more ago. The FIL passed away last week. The project has taken on a new urgency.
    Unfortunately I haven't been able to get the desired results for the corners. The corners are to be triple splined, 45º miter joints.
    Any photos or plans for a miter sled for my tables saw would be appreciated!
    Thanks!
    Ken
    30,002
    Ken, it's not a sled, but I've never had a problem getting dead-on perfect 45 degree miter cuts with my Incra miter gauge. I've got the 1000 SE, but I'd bet the others are as accurate. I put a BB ply sacrificial fence on mine so the cut is well-supported, but other than that, I've done nothing to adjust or tune it.
    Thomasville, GA
    5,987
    This is plan for a miter sled from WoodSmith. It sure looks like it'll do the job. Like Vaughn, I use my Incra 1000SE for some miters. I also use my miter saw successfully after ensuring it's dead on.
    Bill Arnold
    15,806
    Another vote for the Incra SE 1000, since I got mine, I'm always confident of cutting any angle I want.
    I think that the Regular 1000 would be just as good as the 1000SE, I seldom use the flip stop.
    Still for $160 it was money well spent on the 1000SE.
    What is your time worth?
    17,470
    the first question i have fitz is how high are you trying to mitre?that would determine the way you cut them.. the sled that bill linked to will only give you a little of 2" of hieght after you take out the ply thickness and the amount of cut you have on your table saw.. so a 4" tall box wouldnt get cut ...?
    13,427
    I've got the Jessem Miter, which I don't think is made anymore, but it's dead on. They made good products, but their support lacks. If I was to get another, Incra would be on my list.
    Second thing I'd look at is a Wixey (http://www.amazon.com/Wixey-WR300-Di.../dp/B001PTGBRQ) to make sure the blade is at an accurate angle.
    Larry,
    The sides of the boxes are 2 1/2" tall. That pretty well pushes the use of a sled out the door.
    I have a new Tiltbox II tilt gauge and cut the last one with my tablesaw. I wasn't happy with the results.
    I do have a 45º chamfer bit for my router. I may try that with my new router and router table I built this spring.
    Ken
    13,427
    I've had really good luck with the chamfer bit on the router, well actually it was a lock miter, but similar. I even did all the top edges of the box, was only 1/2" stock. Don't have a lot of pics, but originally used it on this humidor.
    https://plus.google.com/photos/11843...873?banner=pwa
    Sounds like your stock may be a bit thicker though.
    Darren,
    My 45º chamfer bit will cut considerably more than 1/2 thick material but the boxes I am building only use 5/8" thick material.
    I need to mow and trim the lawn but later this afternoon I may mill some scraps and make a test run with the chamfer bit.
    Ken
    Honolulu, Hawaii
    1,103
    I have the Incra 1000HD. Paid less than $160 (Amazon) for it and love it. Went on Vaughn's advice. I was building an oak corner cabinet and the miters all fit great. I need to try some small boxes with miter corners.
    Ah,,,to live in Paradise!
    Registered voting member
  1. Incra 5000 miter sled
    By keith Boutselis in forum General Woodworking Q&A
    Last Post: 06-25-2012, 06:16 AM
  2. Is my table saw sled salvagable?
    By Brian Altop in forum General Woodworking Q&A
    Last Post: 02-11-2011, 02:10 PM
  3. Ultimate Bandsaw Table Jig
    By Chris Hatfield in forum Jigs and Fixtures
    Last Post: 01-21-2011, 09:23 PM
  4. Miter Addition to Crosscut Sled
    Last Post: 09-14-2009, 07:00 PM
  5. I need Miter Gauge/Sled help **pics added**
    By Aaron Beaver in forum General Woodworking Q&A
    Last Post: 11-09-2008, 05:52 PM
