Results 1 to 10 of 11
Thread: Side table build
    Jun 2010
    Boston, MA
    145
    Side table build
    So it has been nearly a year since I've been able to get in any shop time. Work, family, and keeping up around the house has managed to suck up nearly all of my time. It has probably been so long since I've been around here, I probably need to re-introduce myself. Hopefully I won't be such a stranger in the future.
    For those with a really good memory, I decided to teach myself SketchUp at the end of last year (thanks again Dave for the help!). You can see the side table build thread where I got lots of great feedback from everyone.
    Two years ago, a good friend gifted me with a nice slab of 6/4" mahogany that she never got around to using. I needed a bit more material for the table and got out to the lumber yard a few weeks ago. Today I got the shop cleaned up, organized, and did a first rough milling of the material. I left everything 1/4" strong over final dimensions and will let it sit for a week to see how it destresses after being cut apart. Was great to make some sawdust. Even started playing with finishing options with some of the cut offs.
ID:	78793Click image for larger version.
ID:	78794Click image for larger version.
    Measure with a micrometer, mark with chalk, cut with an axe.
    12,256
    Matt you aint forgotten and nice to see you back and onto a project.
    10,604
    Welcome back !!!!!
    He lives!!!
    Thomasville, GA
    5,994
    Welcome back, Matt. Looks like a good project!!!
    Bill Arnold
    13,448
    Welcome back Matt!
    Jun 2010
    Boston, MA
    145
    Finally an update....
    Time on the forum has been pretty non-existent for me for the past 3 or 4 months. I have been able to squeeze in a bit of shop time here and there and things are really starting to shape up.
    I finished getting the legs and apron cut out and shaped. First dry fit looks good -- all the joints are pretty tight, maybe a bit of futzing with one or two but overall I'm happy.
ID:	81230 Click image for larger version.
ID:	81231 Click image for larger version.
    At this point I decided to pre-finish the pieces before final assembly. Wasn't quite sure what to do so I made up a sample board out of some of the cut offs. The panels are various combinations of clear shellac, garnet shellac with some dye added, red mahogany stain, alcohol dyes, and/or pore filler. The winner was a coat of clear shellac followed by tinted pore filer. On top of that a thin application of red mahogany stain and tinted garnet shellac. Topped it off with several more coats of clear shellac. Still debating on if I want to give the final piece a few coats of poly or just a few more layers of shellac. Leaning more towards the shellac because it is easier to repair. My family tends to be hard on furniture, so my fear is the poly will eventually get damaged and the repair process will be much more involved.
ID:	81233 Click image for larger version.
ID:	81234 Click image for larger version.
    With the pieces pre-finished, cleaning up the glue squeeze out was easy. I let the glue set up for 30 minutes and it cleaned right off with a sharp chisel. I'm definitely going to use this technique for future projects.
ID:	81236 Click image for larger version.
    With that done, it is time to move onto the top.
    Jun 2010
    Boston, MA
    145
    The original design had a simple mitered corner around the tile inset. Thinking about it, I'm concerned about the joint opening up on me over time. My thoughts then moved toward making a half-lap miter joint. I even ended up making a jig to help get the joints perfect. Took a straight board and cut it as close to 45-degrees as I could. Flipped one end over and put the tips of the angles together -- that way even if it isn't perfectly 45, the angles will be complementary and make a perfect 90-degree corner.
ID:	81240 Click image for larger version.
ID:	81241 Click image for larger version.
    I'm now wondering if all this complexity is worth it. Would I be better off having the top be a simple squared joint with a mortise & tenon? It's less likely to open up or have issues and is easier to make so I'm more likely to get it right the first try. Thoughts?
    I think half lap miters are a fine idea. Depending on the style of the piece, I have no problem with end grain showing from a butted joint. I usually use a bridle versus a butted M&T but, it is a personal choice.
    S E Washington State
    3,777
    Looking mighty good!
    "We the People ......"
  1. A Tiny Side Table
    Last Post: 08-29-2015, 01:48 AM
  2. Project Build: Narrow Office Side Table (video)
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 12-09-2014, 02:12 PM
  3. MMM-CM Side Table
    Last Post: 10-20-2014, 01:31 PM
  4. How would you build this curved side...
    By Art Mulder in forum Designs, Plans and Sketches
    Last Post: 09-04-2012, 01:47 AM
  5. Gridwork Side Table
    Last Post: 08-14-2011, 01:43 PM
