Results 1 to 6 of 6
Thread: Refinish Question re: 1920 Era Cabinet
    Thomasville, GA
    5,992
    Below is the latest addition to our family.
    LOML 'rescued' an Edison Diamond Disc Phonograph (model C-19) from an antique (old stuff) store in a small town just across the line in Florida. From the information available, it was produced after May, 1916 and before 1927 when Edison made the last of them. It's actually in fairly good shape mechanically. Fifteen Edison 'Re-Creations' (records) came with it and it plays just fine. It's amazing how good one of these things sounds without any of the electronics we're accustomed to these days. We did a little cleanup internally, then I oiled and greased the necessary points. I actually found an owner's manual for it online! OK, enough of the good stuff.
    The exterior finish of the cabinet looks decent from a distance, but has a wrinkled appearance up close. It's a tight wrinkled look, whereas the undamaged areas look almost like a French polished finish. I have not done any testing of the surface to determine what topcoat was used. My best guess is shellac, since that was common back then. Before I start doing anything with the finish, I'd like to get your educated opinions on the best approach to deal with this issue. The back of the cabinet has the same appearance, so I can experiment on it first.
    Here's an overall look at the machine.
    This is a closeup of the top edge of the turntable section, showing some of the wrinkled appearance and some smooth area.
    Thanks is advance for your help!
    Bill Arnold
    5,172
    Likely is shellac. My grandparents had a rocker with the same thing. First was to clean it thoroughly. These days I'd use Simple green and copious rinsing. Then some solvent. In the day, my grandma used lye soap.
    Apr 2009
    Outside the beltway
    5,253
    It is french polished , you can take some very fine paper , 400-600 lightly sand the wrinkled areas and polish it of use a cleaner I make up and clean and buff. That's a nice addition.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Jul 2007
    DSM, IA
    5,719
    Bill, this is crazy...I heard one play this past weekend that looks exactly the same as yours. I had never even seen one before and now 2 in 3 days!
    My Website
    Thomasville, GA
    5,992
    I had never heard of this type of Edison machine until my wife told me about it. We did a little online research, then went back to the store to purchase it. It's amazing to me to see how many of the records have survived the decades since being made!
    Bill Arnold
    Thomasville, GA
    5,992
    A good cleaning is the first thing that came to mind, although the cabinet doesn't look "dirty". We've used Murphy's Oil Soap on many things we've purchased but Simple Green might be the better choice on this item.
    Some DA (denatured alcohol) will confirm if it's shellac, of course. One thing I plan to try is wiping with a pad saturated with DA/Shellac similar to French polishing to see if that will smooth the wrinkles as well as refreshing the overall finish.
    My wife and I are preparing to head to Alabama to see her mother, so all of this will wait until we return. Film at 11.....
    Bill Arnold
  1. Finishing 1920's Mahogany
    Last Post: 11-15-2010, 06:35 PM
  2. Refinish Question on Salad Bowl Set
    By Dan Mosley in forum Finishing School
    Last Post: 08-26-2010, 07:54 PM
  3. james-krenov-1920-2009
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 09-12-2009, 03:27 PM
  4. Fredric Bruce Williams - January 11, 1920 - June 8, 2009
    By Nancy Laird in forum Off Topic Discussion
    Last Post: 06-12-2009, 01:09 AM
  5. vintage bass guitar refinish question
    By Chris Mire in forum Finishing School
    Last Post: 08-22-2007, 11:12 PM
