Results 1 to 9 of 9
Thread: kitchen tool refinishing ?
    Aug 2008
    Reno, Nv
    3,632
    Have some old...like 1940's carving knives and serving forks with rosewood handles. They are really dry and in need of some finish. Suggestions?
    Jul 2007
    DSM, IA
    5,719
    Sand them up and soak in mineral oil?? I've got some of the same and was going to do this, but have never got around to it. Never really researched to see if that would be good or bad for them, but figured it should work.
    My Website
    30,008
    Mineral oil would work, but for handles on pieces that will get washed frequently, I think I'd just use BLO, with a buffing after a full cure. The BLO won't last forever, but it'll last longer (and protect more) than mineral oil, and still be easy to repair/replenish down the road.
    Aug 2008
    Reno, Nv
    3,632
    Hmmm...good points. These, like all my good knives never hit the washer. I was on my phone when I did the original post, but the are 40's vintage Kabar's so hot water and soap only!! Thoughts on Formbys tung oil finish?
    30,008
    The Formby's should work, although it might need to be touched up every once in a while. If the handles are rosewood, you might consider just sanding and Beall buffing them with no finish. I've done that with ironwood scales on knives I've put together, and they've held up well. Some of the gloss has gone away, but it's nothing a half minute on the buffer can't fix.
    4,698
    I'd be somewhat concerned that Formby's would just form a surface film and flake off.. I haven't used it for this sort of a thing though so I don't know. If it does it would be easy to fix anyway. Personally I'd lean towards a thinned varnish with a real tung oil base as that would be somewhat more water resistant.. but a dozen or so THIN coats of BLO buffed out or a half dozen coats of a wiping varnish like formby's would be second and third on my list (I admit to having weird finishing biases that aren't all based in reality though so take that into account).
    30,008
    Ryan, the thinned varnish with tung oil would be essentially the same as using Formby's Tung Oil Finish (or any other wiping varnish). And any of them will leave a film finish that's subject to flaking off.
    Pure tung oil (by itself) or BLO would get around the film finish concerns. Tung oil would be a bit more water resistant and tougher than BLO, but it'd take a lot longer to cure, too.
    4,698
    Depends a bit on the "varnish" type, some are more or less film creating than others but the main reason I distinguished it was because the varnish+oil mixes with tung are (imho) somewhat more water resistant than most of the mixes without so are (again just imho) more resilient in this type of use.
    Aug 2008
    Reno, Nv
    3,632
    Re: kitchen tool refinishing ?
    This is a close up...best I can do right now.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  1. need some refinishing help
    By Carol Reed in forum Finishing School
    Last Post: 07-22-2015, 11:36 AM
  2. Refinishing old oak?
    Last Post: 04-12-2013, 08:34 AM
  3. My first refinishing job, complete!
    By allen levine in forum Finishing School
    Last Post: 07-23-2010, 09:11 PM
  4. Refinishing Kitchen Cabinets
    By John Whittaker in forum Finishing School
    Last Post: 12-11-2006, 02:02 AM
  5. Help with refinishing..
    By Greg Cook in forum Finishing School
    Last Post: 11-21-2006, 02:08 PM
