Results 1 to 4 of 4
Thread: The Adventure Continues
    S E Washington State
    3,777
    In my shop redo, using the recycled wood thingy, I have some nice pine boards that were used as shelving. They have been painted. I'm wondering how bad it would be for my planer to run them through it with the paint on it. I'm afraid it will really mess up my planer, and dull the blades. Would it be best to run them through the table saw first to remove the paint before I plane them to the thickness I want?
    "We the People ......"
    5,533
    Well.. two thoughts come to mind... which do you want to 'spend' resources on... rehabbing the painted boards or buying 'clean' lumber? Personally I'd sand down the majority of the paint, then plane them down afterwards. OR just swap out for an old set of blades and use them to take the majority of the paint off and then swap out for the good blades and do a finish pass. A good friend of mine once tried to convince his mother about some recycling thing she was doing. In her case the return on her time was not worth the result. I wonder if the same is true here. Recycling is a good thing, but for your intended purpose is it really the best way? Trust me I'm not naysaying using the boards, just offering up the devils advocate side of things.
    -Ned
    My vote is a low voc stripper. There are some easy, minimal mess products out there these days.
    Thomasville, GA
    5,997
    I use my drum sander to knock off previous finish, then plane as needed. If you don't have one, maybe there's a family member close by who will help.
    Bill Arnold
  1. Kitchen Adventure
    By henry harpending in forum Carpentry and Construction
    Last Post: 06-22-2013, 12:05 AM
  2. my crank organ adventure
    By Mario Marchese in forum Welcome and Introductions
    Last Post: 07-05-2011, 08:44 PM
  3. Off to try a new adventure this weekend
    Last Post: 03-18-2011, 02:06 AM
  4. sawmill adventure
    By John Daugherty in forum General Woodworking Q&A
    Last Post: 12-08-2009, 12:33 PM
  5. Audio-visual adventure.
    By Sam Blasco in forum Flatwork Project Showcase
    Last Post: 10-16-2007, 05:15 AM
