Results 1 to 10 of 24
Thread: Good Deal on Digital Angle Gage
    Dec 2012
    Bedford, NH
    1,683
    Was thinking about getting one of these (Christmas Wish List) & ran across this sale. Looks to be a pretty handy tool.Thought some of you might be interested.
    http://www.amazon.com/Wixey-WR300-Di...al+Angle+Gauge
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    S E Washington State
    3,777
    I've had one for several years. It does a good job as far as I can tell. I only install the battery when I am using it, then when done remove it. Before I started doing that, the battery would be dead when I wanted it. Wixey has another on that is a little fancier, Beall also has a good one.
    "We the People ......"
    I have used the Wixey and the old and new versions of the Beall. All work well. The Beall gives you one more decimal position which could be considered splitting hairs. My poor Wixey didn't survive the last "test drop" but, I have no complaints on any of the boxes. I only change batteries about twice a year. The Wixey takes a Lithium CR2032 and I found that to get one that lasts I had to start buying them as needed and from the pharmacy medical racks. Even though the Duracells and so forth say their good till 2015, this did not prove to be the case. I can say that discount batteries don't last long enough in these things to make it worth even putting them in ;-) This is another plus for the Beall as it uses a standard 9volt which seems to last just fine.
    10,604
    Same issue with the battery being dead whenever I needed it but a quick change of batteries and it works great. I love mine
    30,017
    I have the Beall (the earlier version, I'd guess) and it has always worked great, but for the types of projects I typically do, I found I really don't have a lot of need for it. My tablesaw is set at 90º about 99% of the time, and the other 1% of the time it's at 45º. In both cases, I prefer to just use the plastic drafting triangles I've used for years. They are just as fast, and at least as accurate as the digital gauge. But if I was doing more stuff with odd angles, the digital gauge would be used a lot.
    Thomasville, GA
    5,997
    I got one of the lookalikes from Rockler a couple of years ago...piece of junk...magnets are so weak they won't hold to a TS blade...battery is dead when I want to use it.
    Bill Arnold
    11,833
    Quote Originally Posted by Al Launier View Post
    Handy item. I have one and it works fine. But precautions must be taken with it's use. It measures the angle of the blade (or whatever) but does not take into consideration the position of the saw table. Meaning you can still have whacko angles if you trust the gauge on blade only. The table must be dead level also. For bandsaws the table is adjustable. But very difficult for tablesaws that can be near impossible. To get a true square cut on a ts I still use a steel square. And, I have battery life problems also.
    Dec 2012
    Bedford, NH
    1,683
    Frank, a valid concern, but it's my understanding that the device can be "zeroed" out first, before measuring the blade angle.
    5,321
    Frank: First you put the angle gauge on the table saw's table, and 'zero' it. Then, you put it on the blade, and your angle readings will be correct. That's what the 'zero calibration' is for.
    For the bandsaw, you zero the gauge against the blade, then use it to set the table's angle.
    BTW, Wixey's newest angle gauge has a rotatable screen, and also uses a 'standard' battery, with an auto shut-off. All are great improvements over the original. No interest, just sayin'...
    Dec 2012
    Bedford, NH
    1,683
    The Wixley model WR365 ( http://www.amazon.com/Wixey-WR365-Di...productDetails ) is a bit larger (6.2 x 4 x 1.5 inches) than the mode WR300 ( http://www.amazon.com/Wixey-WR300-Di...productDetails ) which is (4 x 5 x 1 inches). I wonder if the extra length would pose a problem on TS blades & perhaps other application???
  1. Replies: 4
    Last Post: 04-10-2015, 02:38 AM
  2. Digital angle gauge
    By David Johnson in forum General Woodworking Q&A
    Last Post: 01-31-2013, 08:06 PM
  3. Wixey Digital Angle gage
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 03-12-2009, 09:57 PM
  4. Wixey Digital Angle Gauge Sale $29.99
    By Dave Trask in forum Hot Deals
    Last Post: 08-19-2008, 07:46 AM
  5. Wixey Digital Angle Gauge
    By Darren Wright in forum New Tools
    Last Post: 01-05-2008, 12:59 PM
