Results 1 to 10 of 21
Thread: SketchUp Challenge?
    SE Minnesota
    2,524
    SketchUp Challenge?
    Would any of our SketchUp users be up for a challenge? This should be a simple one for you.
    Two 48 in tall, 4 in. square posts with a 2x2 placed diagonally between them such that the pointy ends of the miters are exactly at the top and bottom of the posts. Nothing to it, right?
    The diagonal must measure exactly 2 inches square in cross section.
    London, Ontario
    3,383
    I'm already stuck.
    The rotate tool is letting me down. I'm trying to rotate a 2x2 down into position, but it is working off of the WRONG side of the 2x2, so I can't get the point end lined up with the top of the 4x4.
    SE Minnesota
    2,524
    Art, have you considered drawing the diagonal piece in place?
    There's going to be a catch coming up, right?
Name:	su challenge.JPG
    London, Ontario
    3,383
    Quote Originally Posted by Dave Richards View Post
    I did, but that seemed to me to need a whole bunch of math to figure out the correct cross section.
    Here
    15nov-test.skp
    I tried a different approach. I drew a long horizontal 2x2 precisely straddling the halfway point.
    Then I made marks to set the exact center, and I spun it in place.
    I think this is probably still wrong... I did get the ends to line up with the top/bottom of the post, but it seemed a bit by accident, as I did not see any way to force them to "snap" into place.
    (I did not continue the exercise to clean up the ends of the 2x2s. I figured that wasn't really the point, and I wanted to show how I did it.)
    SE Minnesota
    2,524
    Glenn, now what made you think that?
    You're right, though.
    Did you get it is something still off?
    SE Minnesota
    2,524
    Art, that's good thinking and you got pretty close but it still isn't quite right.
    Take a look at mine.
    Attached Files Attached Files
    London, Ontario
    3,383
    yeah, nothing like zooming WAY in to find the small errors.
    I'll probably keep thinking about this long after my lunch break is done. bad Art. bad bad.
    But right now I'm not getting it.
    I want to approach this like a woodworker: just lay the 2x2 on top of the two posts and draw the line, then maybe transfer it to a miter saw to make the cuts. Done.
    To do that I want to draw a 2x2, select the rotate tool, and then select the face to pivot, and then select the face that is doing the lining up. Right now, SU only seems to let me do the first two. It makes me use the pivoting face as the one that is snapping to a point/line/face. grump grump grump.
    SE Minnesota
    2,524
    Art, think about something else for awhile and we'll get back to this. We'll see if anyone else chimes in.
    I think I got it; 3 components, 2 @ 4x4x48" and 1 @ 2x2x52-51/64".
  1. Advanced (?) Sketchup challenge...
    By Jason Beam in forum Designs, Plans and Sketches
    Last Post: 01-18-2015, 10:17 PM
  2. First SketchUp Challenge of Fall '08
    Last Post: 09-22-2008, 04:00 AM
  3. SketchUp Mini Challenge
    Last Post: 06-28-2008, 07:25 AM
  4. Anyone For Another SketchUp challenge?
    Last Post: 04-22-2008, 03:26 AM
  5. Anyone Up For a SKetchUp Challenge?
    Last Post: 04-14-2008, 11:37 PM
