Results 1 to 10 of 29
Thread: Blanket Box.. the easy way
    Woodstock, Ontario, Canada
    719
    I use Norm's NYW plan for the size of the box, but what I do is make it as 4 raised panel doors and join them together. Got the parts cut out a week ago and yesterday ran them by the shaper cutter. I leave my 3/4" bore cabinet set double mounted on the spare 1/2" shaft. And with a Wixey mounted on it, I can record the height settings in case I have to make a replacement piece. Today I will make the raised panels.
    13,443
    Looking good Bryan!
    719
    test fit of raised panels.
    30,014
    Look great so far, Bryan. I'll be interested to see how you join the corners.
    10,604
    great plan. I've made at least 4 of those.
    Looking good
    719
    I glued the panels together this morning. I have to cut the arc on the leg portion, sand, and I'm ready to glue it together at the corners. I used my new 5 wing panel raiser I picked up from Grizzly during summer vacation a year ago. Sure cuts nice and I like the bead in the profile.
    new york city burbs
    10,188
    I usually cut the arches in legs before I assemble and glue.
    I tape the front legs together, then the back legs, and cut the arcs the same time to get the same cut. Its also easier for me to run them quickly over the spindle sander to smooth out the curve.
    Human Test Dummy
    719
    On my version , because of the cope and stick , I start the cut at the bottom edge of the panel. What I have done is make 4 doors with the ends left long for the legs. That's what makes construction of this box easy.
    new york city burbs
    10,188
    I saw that in you pics, I was wondering, is bryan going to leave the dados from the cope set on the legs?
    I was going to ask, but I figured eventually youd cut off the grooves and put some kind of form on the bottom of the legs.
    I made one box like that. I only have one standard kitchen set, but Ive gotten my moneys worth out of it.
    when my daughters college roommate got married in buffalo ny this past summer, I was going to make a box pretty similar to yours, using my cope set, and just attaching 4 glued up sides,I ws thinking about one of those drawer making bit sets, a paneled top, and put in cleats and add a plywood bottom covered with cedar.
    I was just about ready to start, when my daughter told me she decided to flly up and not drive, so I had no way of getting it up to her, took that project right off my list.
    Im starting bandsaw reindeers today, my big project for the winter.
    Human Test Dummy
    719
    So, with line locate work dwindling, I got 2 hours in the shop yesterday . I'm taking winter layoff today so I can get some shop time in for the next 15 weeks.
Name:	line locator.jpeg
    I leave the legs over length, sand the top edge of the panels flat, then run them all through the table saw to trim the legs to length. Then mark and cut the curve on the legs. Careful doing the jigsawing, only need slight drum sanding to smooth.
ID:	79476Click image for larger version.
ID:	79477Click image for larger version.
  1. blanket chest.
    By Chuck Thoits in forum Flatwork Project Showcase
    Last Post: 12-20-2009, 02:19 PM
  2. A blanket apology
    By Jiggs Elphison in forum Off Topic Discussion
    Last Post: 11-08-2009, 05:52 PM
  3. Blanket Chest
    By Cody Colston in forum Flatwork Project Showcase
    Last Post: 08-20-2008, 03:13 PM
  4. Blanket chest
    By Doug Sinjem in forum General Woodworking Q&A
    Last Post: 08-13-2008, 06:42 PM
  5. Another Blanket Chest (Toy Box)
    By Mack Cameron in forum Flatwork Project Showcase
    Last Post: 10-10-2007, 06:23 AM
