Results 1 to 9 of 9
Thread: I discovered the best way to cut Polystyrene...
    London, Ontario
    3,383
    Hey Folks,
    I just had to take a moment to share what I've learned today.
    I have learned the absolute best way to cut polystyrene (aka: white styrofoam) in your shop.
    It works the best. Guaranteed.
    Here is the best way to cut polystyrene in your shop: Don't.
    My wife is half of the banner c'tee at church, and they decided that this Christmas they wanted to hang a large star in the church as part of the Advent decorations. I helped her design one in sketchup, and today she came home with two 4x8 sheets of 1-1/2" polystyrene. we designed a simple(?) 6ft tall, 3ft wide 4 pointed star. We designed two of them, one notched at the top, one at the bottom, so that they could interlock together.
Name:	Screen Shot 2013-11-29 at 9.05.05 PM.png
    Then we went down to my shop to cut it out with the bandsaw and jigsaw.
    What a mess. We had a shopvac hooked up to the small 14" bandsaw, but there was still white bits of polystyrene everywhere. We had it up and down our clothes. The jig saw was coated. There were bits sticking all over the place. I vacuumed us, I vacuumed the tools, I vacuumed the sides of the cut styrofoam, I vacuumed us again, and then did the whole round again trying to suck the little pieces that were stuck by static everywhere. Undoubtedly there are still little bits that I'm sure I'll find tomorrow.
    Y'know, sawdust might be a bit messy and a known carcinogen, but at least it has the decency to obey the law of gravity!
    13,361
    Yeah, I've had much better luck with either a very sharp long blade from one of those snap off knives, or with an electric knife.
    What Brent said but, . . . you've learned that the hard way. You'll find particles of that stuff stuck hither and yon via static electricity for a long time to come ;-)
    Jun 2007
    4,944
    Yeah! And the stuff loves bandsaw tires---the longer you leave it, the harder it is to remove. DAMHIKT.
    Enjoy,
    JimB
    VOTING MEMBER
    11,833
    Electric carving knive. Available in every resale shop everywhere cheap.
    Melbourne, FL
    472
    I built a foam and fiberglass aircraft (I always get excited when a post says new plane).
    Asked many other builders if they could only have one powered tool what would it be. Got many answers.
    My answer soon turned out to be a very good shop vac!
    Jan 2010
    Victoria BC
    87
    If you only have a little to cut you can mount an abrasive blade (metal cutting) in your table saw or circular saw. It will melt its way through' If you have a lot to cut or complex shapes get a hot knife or better yet a hot wire cutter. There are several designs on a site dedicated to building your own tools that was posted to another forum a few days ago Here is the link:
    http://www.homemadetools.net/
    Oct 2007
    Nova Scotia, 45N 64W
    1,245
    Hey Folks,
    Sounds like a Lucille Ball skit Art
    If I can't avoid working with the stuff, I just use a straight edge and a box cutter, with a new blade fully extended. Seems to keep the chaff to a minimum. Your results may vary.
    12,258
    BTDT, i was too embarrassed to post a warning otherwise i might have saved you from this disaster of a mess. I had a go at cutting a big slab of polystyrene to make some fancy corner protections for my travel trailer just before packing it away for the winter. The gutters on each corner ripped my cover last year and normally they are removable except not on mine. So i took a block of the thick stuff and cut it to all sorts of shapes and then hotglued it together to go over the protruding gutters. Along with duct tape to hold it in place while i put cover over. Solution worked but then came the clean up. I had to vacuum half the yard to get the white balls collected. To say nothing of what it does to a shop vac filter. Sorry i did not post a warning Art, i might have saved you.
  1. I may have discovered the 8th Wonder of the World
    By Jim C Bradley in forum General Woodworking Q&A
    Last Post: 03-27-2015, 03:31 AM
  2. i think i just discovered.......
    By Rich Soby in forum Off Topic Discussion
    Last Post: 06-03-2013, 12:36 AM
  3. Discovered something new
    Last Post: 06-26-2010, 10:29 PM
  4. Antartica - new penguin discovered
    By Rod Upfold in forum Off Topic Discussion
    Last Post: 12-17-2009, 09:34 PM
  5. I Discovered Sharp Today
    By Brian Gumpper in forum Neander Woodworking Q&A
    Last Post: 11-28-2006, 01:40 AM
