Results 1 to 4 of 4
Thread: Using an ROS as a buffer
    Feb 2012
    2,749
    My wife put down a coat of wax over the WOP I had applied to the dining room table, and buffed it by hand. She wasn't saatisfied with the result, so I went out looking for a buffing pad for a drill. I had to go to four stores before I found one at the local Canadian Tire. It was a lambswool buffer with a 5" diameter hook and loop back, so I said, "Hey, I can use it on my ROS!"
    So I just put it on the ROS, and though I was afraid the buffer would turn too fast, it turns quite slowly unless I use very, very light pressure. It left an even semigloss sheen on the quarter of the table I've done so far, but I'm wondering if I can hurt the motor if I continue, and maybe I should get the kit that attaches to a drill before I continue?
    Cheers,
    Roger
    Thomasville, GA
    5,998
    A few years ago, I picked up a Turtle Wax 6" buffer that uses a variety of pads. It was under $30, as I recall and worked fine on a couple of items I needed to buff out.
    Bill Arnold
    30,017
    I seriously doubt that buffing will be any harder on your ROS than sanding is. Plus, because the orbital motion is random, you're less likely to get visible swirl marks.
    5,172
    I got a car buffer on sale at the autoparts store. Think it was $29 plus a few extra lambswool pads. Super tool. Probably 8" in diameter. I just wash the pads and I am good to go.
  1. Long Arbor Buffer
    Last Post: 03-06-2011, 02:22 PM
  2. Buffer
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 02-08-2007, 04:27 AM
  3. Buffer
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 02-07-2007, 09:32 AM
