Results 1 to 8 of 8
Thread: Back in the saddle
    Aug 2008
    Reno, Nv
    3,632
    Back in the saddle
    Carbon fiber casting I picked up in a swap a while back...not thrilled with the cut ends, but it works over all. Next is a blank also from a swap cast from wood shavings from the pen I received. Last but not least magnum bullet with stabilized buckeye burl and some worm holes filled with turquoise. On reflection, I'd rather have used gold Pearl-ex to highlight the yellow in the blank. Thanks for looking!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    Jan 2011
    3,798
    Feb 2012
    2,746
    Especially like that first one! So now you've got a burr in the saddle?
    Cheers,
    Roger
    10,600
    Nice
    How do you fill the hole with turquoise ??
    Aug 2008
    Reno, Nv
    3,632
    I am the burr in the saddle Roger!!
    Aug 2008
    Reno, Nv
    3,632
    Nice
    I have 2 kinds Bob...crushed and powder. These are 1/16" holes, to big for the crush. Just rotate the spindle until the hole is facing up, tap in a little powder so it's well above the surface and add a drop of thin CA. Turquoise is hard as a rock, pardon the pun and very hard on tools so I revert back to a carbide cutter to level it out. Repeat if necessary and finish as desired.
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    A bit too large for the screen, but they do look great from here Jim.
    Well done.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    30,002
    Good-looking pens there, bud.
    Les, I think the size issue is because the pics are loaded directly from Jim's phone via Tapatalk. They fit if the monitor resolution is higher than the 1280 pixel width of the photos.
  1. Back in the saddle again
    By Ron Hossack in forum Lathe Project Showcase
    Last Post: 06-12-2012, 06:46 PM
  2. Back in the saddle again.......
    By Ken Fitzgerald in forum Off Topic Discussion
    Last Post: 02-22-2012, 09:10 PM
  3. Back from Vacation and saddle sore
    Last Post: 08-27-2009, 02:34 AM
  4. GLOAT! Back in the saddle!
    By Gord Rock in forum Turning Tool Questions and Show & Tell
    Last Post: 04-04-2008, 04:18 AM
