Results 1 to 10 of 15
Thread: Suround boom
    13,438
    Suround boom
    One thing I've been working on during my week off was to install my Suround sound again. My wife fought tooth and nail to not have the wall warts, so I installed those in the shop and bought new Yamaha ceiling speakers for the living room.
    I had to add a couple of access holes to the heating duct chase, which will get wall plate covers, to get all my wires run without having to remove drywall.
    I have the sun room side opened up and will be removing the windows in a couple of weeks. Also will have speaker patch panels on this wall as well as in the closet where the equipment is currently. I just havethe cables patched for now so we can try out the speakers.
    The tv will be moving on the other side of where the closest window is. Audio and video equipment will be on this side. The large set of windows will become an opening, had to move the electrical above, which is why all the drywall is removed. The far window will be closed up.
    13,357
    That looks like a lot of work! Still, I would like to run the surrounds up in my ceiling, but just not much of a good way to get there from here.
    13,438
    Yes it was, I'm feeling it today too.
    Luckily I had a 4' long 3/4" drill bit, which needs a sharpening now. I had to drill through 4 headers, 3 of them vertically through the center (plywood filler between outer 2x10's). Those fiberglass pull rods from HF worked great, best $9 I've ever spent, used them the weekend before last to pull in wires for my FIL's surround sound too.
    30,008
    Nice-looking installation so far, Darren.
    I think LOYL was right. Nice clean look there.
    Yorktown, Virginia
    5,009
    That's a nice clean look. No big bulky things to take up space or chords to try and hide. I wonder how the ceiling speakers sound. Are they designed for that specific purpose? I have a real old school set up and recall there were optimum locations for all the speakers....usually some place where they stood out like a sore thumb. Hard to fit these old Klipsch La Scallas into the ceiling
Name:	speaker 002 (Small).JPG
    13,438
    The speakers sound good, but I'm waiting on an optical cable to feed the sound back from the tv to the AV Receiver to get full 6.1 sound as my AV Receiver is old enough that it doesn't have HDMI through-puts. The speakers frame is about 10" in diameter, there is a 6" speaker mounted on that at an angle so that you can turn and tighten it in the direction you want it to project. The tweeters on them are also somewhat adjustable for direction. I cut a bat of 4" insulation about 1 1/2' long and laid above each speaker, but mostly to keep the sound from resonating upstairs less. The sub box still sits on the floor outside of the AV closet, but it's under a table and not that noticeable.
    I may replace the AV receiver down the road, but it sounds a whole lot better than just the TV's factory speakers. The main purpose was make hearing the tv easier when other noise is happening in the house. My wife tends to turn it way up to drown out the kitchen TV, which in turn gets turned up and it becomes a battle of the volumes. Our kitchen tv gets used about as much and I'm seriously considering a surround sound there as well so we can hear it over the exhaust fan on the stove.
    Aug 2008
    Reno, Nv
    3,632
    In this case...I'm glad we have a small house!! But some really cool ideas Darren since our living room and patio share the same wall and several holes for sat and what not's. Mucho inspiration and clean lookin' work!!
    13,438
    Ted, I meant to mention, most of the new AV Receivers come with a microphone you plug in and set it where you will be sitting. You run it through a setup process and it will make some hums and ticks and adjust the output to each speaker for the what it determines to be the best settings, pretty slick stuff.
    Yorktown, Virginia
    5,009
    That's what I need! My receiver was top of the line ....in 1985
  1. Boom Boom, Out go the Cabinets....
    By Stuart Ablett in forum Flatwork Project Showcase
    Last Post: 08-27-2014, 12:30 AM
  2. Crash, bang, boom
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 10-03-2013, 02:08 PM
  3. In the wall Aquarium Cherry suround
    By Joe Acquisto in forum Flatwork Project Showcase
    Last Post: 11-30-2012, 07:21 AM
  4. Replies: 0
    Last Post: 04-30-2012, 12:28 PM
