Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
Thread: Small roll top desk for a Granddaughter
    Woodstock, Ontario, Canada
    719
    Our daughter wants a desk for her 10 yr old. I found a free roll top plan, and making a few modifications.
Name:	roll top desk charis.jpeg
    I added 2" to the leg length so a pencil drawer could be installed. And I want to use a ball and socket tambour so no cloth backing .
    I made up a jig to cut the tapered legs on the TS's slider. The jig bolts to the slots in the slider, scrap wood is built up to mount the hold down clamps.
    I made up a template from 1/2" MDF to rout the groove for the tambour .
    4,699
    Thanks for showing the jigs, always fun to see Looking forward to seeing the rest of the build!
    719
    Found my old board buddies hold down wheels and mounted them on a wood strip clamped to the top of the fence. Made up 20+ strips, need approx 16 strips for the desk.
ID:	79820Click image for larger version.
    Thomasville, GA
    5,994
    Bill Arnold
    719
    The shop made shaper cutter worked great! I had to make a minor adjustment to one area of the cutter on the grinder. Glad I made an extra amount for test strips, took a few passes before I got it producing a suitable shape.
    shop made shaper cutter from Craftsman molding head knives, old test pieces from last desk I made.
ID:	79851Click image for larger version.
    719
    today I milled the socket. Double pass on TS to 1/4", then 1 pass over a steel 1/2" dia. core box 1/4" shank bit. I still have to round over the bottom edges and sand them. I made enough for 21", need approx 18-19" + the 2&3/4" starter strip the handles mount on.
ID:	79881Click image for larger version.
ID:	79882Click image for larger version.
ID:	79883Click image for larger version.
    719
    Routed the groove in the sides. 1st try, router went off the template, glue up more wood. Then found out the template needed adjusting, curves too tight for this style of tambour strip. Trying to re router the groove caused some tear out so had to replace 1/2 a side. Finally got a functioning tambour. Test fit.
ID:	79924Click image for larger version.
    17,472
    well here we thought you never had miscues bryan and on this you had two well the rest of the year should clear sailing
    719
    When you make one off items, theres always a learning curve. Like Norm, this one's the prototype, next ones perfect! I hope!
    Jan 2011
    3,798
    Quite enjoyable
  1. Small Project For My Granddaughter
    By Dan Mooney in forum Lathe Project Showcase
    Last Post: 08-13-2014, 12:03 AM
  2. Roll top computer desk W.I.P.
    Last Post: 03-12-2012, 04:38 PM
  3. roll top desk in pine
    By matt fonner in forum Finishing School
    Last Post: 08-22-2009, 03:24 PM
  4. small corner desk ?
    By Stephen Bellinger in forum General Woodworking Q&A
    Last Post: 07-06-2009, 11:18 PM
  5. small walnut desk
    By Mark Kosmowski in forum Flatwork Project Showcase
    Last Post: 06-19-2009, 06:11 PM
