Results 1 to 6 of 6
Thread: A little patch
    13,464
    A little patch
    When running my speaker wires, I ran into an issue with a miscalculation/location of a joist. It was about a 1/2" from the edge of my duct chase. So I attempted to remove the edge trim and drill under it up between joist and inside edge of chase. The angle wasn't enough an I would have drilled right up the middle of the joist, so I had to drill a few inches over at an angle to avoid damaging the integrity of the joist. I debated about removing the rest of the trim and overlaying it with a sheet of veneer, but remembered I had a couple of pieces that were cut out of the side I was putting plate covers over.
Name:	2013-12-12 22.06.25.jpg
ID:	79817 Click image for larger version.
Name:	2013-12-15 13.45.28.jpg
    I used a hole saw and cut a plug at an angle to match the hole
Name:	2013-12-15 14.33.15.jpg
    A little filing I had it fitting, could use a little putty on one side, but I'm happy with the fix, it's pretty un-noticeable.
Name:	2013-12-15 15.19.21.jpg
ID:	79815 Click image for larger version.
Name:	2013-12-15 19.27.20.jpg
    Yorktown, Virginia
    5,022
    Nice fix Darren....looks like it blends right in and you're the only one who knows its there.
    What? That knot? Nah, it's always been there.
    10,604
    What patch ??
    Jan 2011
    3,798
    Holy woodworking Patchman
    9,077
    "Guaranteed to work as quickly and easily for you at home, as it does on TV" Great fix. Disappears like magic!
  1. stuco patch?
    By Al killian in forum Carpentry and Construction
    Last Post: 10-12-2009, 07:16 PM
  2. Paneling patch
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 11-17-2007, 01:46 AM
