Results 1 to 7 of 7
Thread: Bottle Stoppers
    Bottle Stoppers
    I am new to making bottle stoppers and I have made the first few without problems but now I am having trouble with them when I put them on the 3/4 mandrel the stopper becomes loose and hard to turn. I drill the holes with a drill press and the recommended drill bit size but I keep running into the same thing. Is there a secret to this or am I just doing things wrong?
    Diana
    5,167
    Hey, Diana.
    First welcome to FWW. Always room for more girls.
    You likely will get more responses if you repost in the turning forum. Just click on the Forum box on the upper left and scroll down to the Turning Forum.
    ...and we like pictures. They're full of ever so many more words.
    Aug 2008
    Reno, Nv
    3,632
    Hi Diana and welcome!
    When you say "becomes loose" is the blank un-threading or is the morse taper coming loose from the headstock?
    Yorktown, Virginia
    5,005
    Welcome to FWW Diana. Glad you found us. It might be helpful if you post a few pictures of your set up. Possibly start out with the blank on the mandrel but also between centers (bring the tail stock up to help hold the piece). Once you have the blank roughed/rounded you can back off the tail stock and continue turning. The initial roughing without tail stock support might be the problem. Just guessing though.
    new york city burbs
    10,184
    depending upon the material youre using, acrylic, hard wood, soft wood, you might have to pay attention to the size bit youre using.
    if you just go down using a bit 1/64th less, it will be harder to thread, but will not loosen up on the mandrel.
    Human Test Dummy
    S E Washington State
    3,777
    Welcome to the forum! It would be helpful to see your set up, like mentioned. If your blank screws onto your mandrel, like a Ruth Niles mandrel, it can be helpful if you screw the blank on, then screw it off, coat the threads with some thin CA to make them stronger and when the CA dries, screw the blank back on. This applies if you are using wood for your bottle stopper. A slightly smaller bit helps also, as stated.
    "We the People ......"
    I don't post much but when I do bottle stoppers I can't think of one reason why to drill a hole, thread the hole with a tap and screw the stopper into that hole. Everyone I've asked that uses this method I asked how many of them took the stopper apart after making it. The answer was zero.
    A local friend has improved this method tremendously ... You don't need to buy a special mandrel, a drill or a tap.
    He made a Bottle Stopper Pen Mill that uses a "Z" drill bit that you drill the hole, epoxy the SS304 stem into the hole and then turn. Used the standard silicon stopper from CSUSA or Woodcraft.
  1. new bottle stoppers
    By Dan Noren in forum Lathe Project Showcase
    Last Post: 01-27-2010, 01:39 PM
  2. Bottle Stoppers
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 10-23-2009, 01:39 PM
  3. Some Bottle Stoppers
    Last Post: 10-01-2009, 03:07 PM
  4. Some bottle stoppers
    By Chuck Beland in forum Lathe Project Showcase
    Last Post: 08-27-2008, 01:48 PM
  5. Some bottle stoppers
    By Don Baer in forum General Woodturning Q&A
    Last Post: 11-01-2006, 02:29 AM
