Results 1 to 10 of 12
Thread: How do I make a bushing smaller
    10,604
    The bushings I need for the new Knights Armour pen from PSI are backordered until January. I have orders for 2 of the pens for Christmas.
    I have bushing that would work but they are .522 in diameter and the diameter I need is .495.
    I can't find any local machine shops to do help. It's probably a 5 minute job at best.
    If I could mount the bushing on my lathe I thought that maybe a file or carbide lathe tool might work but I've no clue as how to mount them.
    Any ideas ?????/
    Southeast Pa
    2,019
    i'd just mount on y mandrel with spacers ,wood would be fine, and use a file to get close finishing up with paper. just pretend they are the pen..
    I agree with Garry. Mounting is easy...you do it every time you turn a pen. You could even use blank brass tubes as spacers between the bushings on the pen mandrel, but I'd use wood like Garry suggested just to avoid the chance of messing up the ends of the tubes. Once the mandrel is loaded and mounted, a file and some sandpaper should do the trick. to reduce the diameter.
    Dec 2012
    Bedford, NH
    1,683
    You could take a dowel that is a bit undersized, split one end a bit, slide the bushing over the split end, install a small shim or wood screw to wedge open the split end until it's a tight fit with the bushing I.D., them mount it on a lathe or drill press by the opposite end, & then sand the O.D. of the bushing.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    ďThe problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    North West Indiana
    6,099
    Or if you have a micrometer, put slimline bushings on each end and turn and measure. The heck with meeting a bushing, turn it to measurement. It really isn't as hard as it sounds. Calipers set a hair wide and sand to diameter if it makes you nervous.
    Jon
    Aug 2008
    Reno, Nv
    3,632
    You should have the measurements of the bushings from your instructions...although I seem to lose those on an hourly basis!! Get your dial caliper or micrometer out and go at it! Never try to file existing bushing unless you are exact and can polish them to exact measurements. Pens are exacting and the Opps's are easily seem and felt!! The best is always good enough.
    S E Washington State
    3,777
    I'd do it with undersized bushings and use a micrometer as suggested. I always us a mic even when I have the correct bushings. I don't trust them or the hardware for the pen to be exact. I measure the hardware where it meets the blank and turn to that, leaving a little shy to make up for the finish on the blank.
    "We the People ......"
    13,361
    You could always use some dense plastic or hardwood and make a bushing. Really, they are there as a guide to the size, you shouldn't really be hitting the bushing with your turning tool anyway...
    I'd say either make some, or just go undersized and measure with a micro.
    10,604
    Great suggestions, thanks
    They all make sense and I feel comfortable with most of them. I have a go at it in the morning and let you know how I made out.
    You couldn't afford the shop labor for that.
    When I don't have the bushings I need I usually make my own from Delrin rod. If you use a mandrel drill a 1/4" hole, mount and turn down to size. Quick easy to turn.
    If you have some bushings that are smaller in diameter I've used masking tape to build up the OD until the desired size.
    There are quite a few bushings that are in that ballpark of 0.495 ... Do you have any Polaris/Cabara bushings? Woodcraft has bushings for the Classic American Twist with that OD. PSI actually has quite a few with that OD (Majestic Squire, Art Deco, Diva)
  1. New 'smaller' Crosscut Sled
    By Ned Bulken in forum Jigs and Fixtures
    Last Post: 01-01-2013, 02:40 PM
  2. smaller gun??
    Last Post: 01-15-2011, 05:35 PM
  3. Simple router bushing fix
    By larry merlau in forum Jigs and Fixtures
    Last Post: 01-30-2010, 06:10 AM
  4. Making my shop smaller...
    By Ned Bulken in forum Carpentry and Construction
    Last Post: 12-11-2009, 04:09 AM
  5. how do i make my sketchup file smaller?
    By Mike Gager in forum Designs, Plans and Sketches
    Last Post: 02-09-2009, 10:29 PM
