Results 1 to 10 of 12
Thread: Planer Question
    Dec 2013
    North Okanagan
    83
    Planer Question
    I have a delta thickness planer (model 22-560) and have been having a considerable amount of trouble lately with pieces stopping part of the way through and usually more than once. It is really annoying because it leaves small indents wherever the knives were sitting still spinning for a while. It doesn't seem to matter whether I am removing a small or large amount of material. Maybe there is something wrong with the feed rollers??? Has anyone else had this problem???
    Another interesting thing is I don't seem to be getting any planer snipe
    "If they don't know you personally, don't take it personal."
    S E Washington State
    3,777
    Had that problem just the other day, planing some purple heart. Haven't had time to look at it yet. Last time it did that I cleaned rollers as best I could, waxed the table top and it started working again. I hope I am as lucky this time. Seems like I read somewhere that you can take the rollers our and clean them in warm soapy water. I have not tried that because I do not know how hard they are to remove.
    "We the People ......"
    Planer Question
    I've wiped the rollers in my planer down with denatured alcohol to make them more "grippy". Be careful that you don't cut yourself on the blades, though.
    Dec 2013
    North Okanagan
    83
    Ok so I cleaned and waxed the table, hmm denatured alcohol, not sure where to get that. Would methyl hydrate or regular rubbing alcohol work???
    Oops, didn't realize you were in Canadia. Yes, methyl hydrate should work the same as denatured alcohol (often called DNA here).
    I've also seen similar issues when the blade on my planer got dull.
    Dec 2013
    North Okanagan
    83
    Well, three coats of Minwax Paste Finishing Wax (I love that stuff) later and cleaning and rubbing down with methyl hydrate on the rollers and it works perfectly again! Now to go finish that project before christmas eve
    Good to hear it's handled, Michael.
    Apr 2013
    Nashua Iowa
    130
    I am glad to hear it is working for you. If the same problems pops up in the near future it could be that a roll pin in your drive train got sheared and it is slipping catching and then slipping again. I happened to m once a long time ago. I have never had a lunch box planner, so I wouldn't have thought of the fix that the others have told you. I hope they solved the problem for you, But if not at least now you know where to look.
    Feb 2012
    2,749
    Quote Originally Posted by Paul Douglass View Post
    My problem with that sort of thing is, how hard are they to put back?
    Cheers,
    Roger
    Dec 2013
    North Okanagan
    83
    Quote Originally Posted by Tom Bussey View Post
    Thanks. It did seem for awhile like something like that was happening but it is kinda hard to check easily
  1. Planer Question
    Last Post: 09-30-2013, 06:47 AM
  2. Planer Question. Need one.
    By Mark Rice in forum New Tools
    Last Post: 05-19-2011, 12:56 PM
  3. Ned, you still need a planer? (serious question embedded)
    By Mark Kosmowski in forum Old Iron
    Last Post: 02-21-2009, 08:41 PM
  4. Hand planer question
    By curtis tolbert in forum General Woodworking Q&A
    Last Post: 06-07-2008, 07:51 PM
  5. Planer question
    By Billy Burt in forum New Tools
    Last Post: 11-12-2007, 02:59 AM
