Results 1 to 2 of 2
Thread: Used a .410 Gauge
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    Used a .410 Gauge
    Solid brass shot shell for the barrel on the 30 cal Bolt Action.
    The .410 casing has a .466" diameter and is a perfect diameter match for the fittings.
    Cut to length, polished and applied 6 coats of automotive lacquer using my "Dipping Method"
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    Aug 2008
    Reno, Nv
    3,632
    That sir, was not easy! That will pad the retirement fund!!
  1. Woodpecker MT gauge
    Last Post: 01-20-2014, 02:57 AM
  2. New Marking Gauge
    By Tom Becnel in forum Handtool Project Showcase
    Last Post: 10-29-2012, 06:46 PM
  3. Replies: 0
    Last Post: 04-16-2012, 01:43 PM
  4. Marking gauge conversion kit to mortise gauge
    Last Post: 09-03-2010, 03:55 AM
  5. 23 gauge pin nailers?
    By Carol Reed in forum New Tools
    Last Post: 11-17-2009, 03:59 AM
